Question about HP Pavilion dv1000 Notebook
HARD DRIVE is not detected
I have a HP laptop when start the problem the display show that hard drive need to be tested and after completed I can see first windows screen but never start up I see screen with safe mode but it's not start it frozen when I tried a windows XP recovery CD, it's says not Hard drive detected and run BIOS and it's not hard drive detected. Hard drive model seagate HP # 395292-003
May I recovery this hard drive? or I need to buy a new Hard drive?
Thanks
Michael Z.
  • Anonymous Jul 12, 2008
    just disable the SATA device in your bios and your HDD will be recognized.
    Sergeant:
    Champion:
  • 256 Answers
Hi
Yes, problem with hdd you need to buy new hdd, no other choose....
Thanks
Posted on May 02, 2008
My laptop displays Smart Hard Disk Error please help, it says the following: The Smart hard disk check has detected asn imminent failure.
This error message means you need to copy/backup the data on this hard drive before it fails completely. When the hard drive fails completely you will have to replace it.
Mar 19, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
I have a HP G70 - 120EM laptop and it shows "no
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 11, 2013 | Computers & Internet
I am getting the error message-"Hard drive not
it caused the hard drive malfunction try open the bios and try to read the hard drive is your hard disk stll there. in some case on the hp compaq laptop the hard drive was detecting eror but it can be use to external hard drive.
you can find some usb to mini ata or usb to sata to try your hard drive on another laptop or pc(make it external hard drive)
Jan 14, 2011 | HP Pavilion dv5-1132us Notebook
It said problem on hard disk, install hard disk.. how to install where to get it my netbook has no dvd/cd compress HP mini
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. If the computer has two hard drives, you should select the multi-bay test option and test each drive separately.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test. NOTE: The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
Instruction on how to Install a new HDD
Please follow the link
Thanks
Proton
Sep 03, 2010 | Computers & Internet
Hard drive crashed
NOTE:
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion Dv5-1008TU Hard Disk / Hard Drive not detected.
The hard drive test could not detect the hard drive, indicates a faulty drive.
Also if the drive does not spin up or is making clicking sounds then the it is definitely faulty.
You need to buy a new drive.
Mar 10, 2009 | Acer Aspire 5050-3242 Notebook
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
1720-SMART HARD Drive detects immenent failure. What shall I Do?
Sounds like your hard drive is about to pack up. You can disable SMART for your hard drive in your CMOS setup. which will allow you to boot up your pc. I suggest you back-up all your data as soon as possible before the hard drive fails completely.
Nov 29, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
HP Pavilion dv1000 Notebook Logo
300 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
