Question about Seagate 25PK 160GB ST3160215AS SATA 7200 RPM 2MB 3.5IN 160 GB SATA Hard Drive
I using external CASE and connected in USB port.. but its detcting but it not shown in my computer.. i need anwswer plz.. is any JUMPER to place?
    Brigadier General:
  • 10,406 Answers
SATA drives do not have any jumpers.
If you were the one who mounted the EIDE drive into the external-case, be sure to set the jumper to "master" (not "slave", and not "cable-select").
Try connecting the external case to a different computer, to see if the unit works at all.
Remove the disk-drive from the case, and connect it as a "slave" disk-drive in some desktop computer, to see if it can be detected at all, when _not_ using the USB-to-Disk-Drive adapter.
Posted on Aug 19, 2010
USB not recognised in computer section?
Try connect any battery-operated external USB device (eg MP3 player, etc.) to the USB port. Does it work? If does, so it is interrupted +5V power supply of USB port on your notebook.
Mar 16, 2015 | Acer Aspire 5335-2257 Notebook
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
Have taken hard drive from desktop want to know how to convert it to an external hard drive for laptop
You need to purchase an USB hard drive case and insert the hard drive into this USB case. You need to remove the jumper on the hard drive or set it to master drive. Power up the laptop then then power up the USB hard drive and then connect it to your laptop's USB port. The laptop will then detect this as a new device and will show up as an external storage device.
Jul 26, 2010 | Samsung SpinPoint V60 SV0602H 60 GB Hard...
Hardisk is not detcted on any computer
1.check the USB cord
2. the controller to the USB drive could faulty.
3.the usb port could be damaged / try another port.
***I hope this helps. Have a great day!***
Jul 10, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
My external hard drive is not showing up
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Oct 02, 2009 | Western Digital My Book Essential Edition...
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
Installing an external drive
Check the jumper setting on the back of the hard drive and make sure it is set to master. You may also have to install the driver for your external case, should have came with and install cd
Jul 13, 2008 | Electronics - Others
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Seagate 25PK 160GB ST3160215AS SATA 7200 RPM 2MB 3.5IN 160 GB SATA Hard Drive Logo
119 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
