Question about RCA RS1285 CD Shelf System
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
  • Melvin Johnson Dec 12, 2014
    That happened to me too. Everytime I put a CD in, it never reads it, once it worked when it was just a plain clean CD. But since then it can't play none anymore. Some parts they put inside might be weakened.
  • 979 Answers
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Posted on Aug 19, 2010
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
My teac dv223 won't read any disks,
Try cleaning the lens. You can get lens cleaners for CD/DVD players.
Nov 17, 2012 | Audio Players & Recorders
My RCA stereo(RS 2620) will not read discs...
it might be the steiro cant read the disk because the cd is scratched or maby it cant read the cd cuz if you put the songs on a cd it might not read hope this helps!!!!
Jun 03, 2009 | RCA RS2620 Single Cassette Deck
Cds won't play
im in the same boat as you...we have one of those as well and the cd's wont read...only the fm and tape work
Mar 16, 2009 | RCA Audio Players & Recorders
Peugeot 406 cd player works when ignition is on but when engine is started cd player wont work. Radio is fine.
Just bought 2001 peugeot 406.The radio worked perfect but CD player not reading disk or operating.That was until I realised that the CD for driving safety will not allow you to put CD into it while driving or engine running.Switched off engine then switched it to 1st batt light position & CD worked perfectly.But when I then switched key off & then started it was back to not operating.I then realised that the CD player for safety will not operate when engine is running unless you let the CD start operating first pre engine fire then wait a little more time before starting .Now it should work properly though it will not allow even the passenger to change a disk while being driven. On disk change you have to go through the same start proceedure.Hope this will get your CD working.Sherlock ??
Jun 29, 2008 | Audio Players & Recorders
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
Jan 04, 2008 | Califone International (2385AV-02 ) Single...
Wont play cds burnt by new computer?
is the files your burninthe same format m8 ie mp3,wma
Dec 09, 2007 | Stanton C.313 CD Player
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Nov 10, 2006 | GPX C984 Boombox
RCA RS1285 CD Shelf System Logo
1,035 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
