Question about Buffalo Technology 1TB DRIVESTATION COMBO TURBO EXT USB20 FW400 SATA 7200RPM USB 20 Hard Drive
My buffalo 1TB drivestation HD-CXU2 causes my pc computer to hang. I use Windows xp, Pentium processor with about 500mb memory. Any suggestions?
Crankstart
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 09, 2009
kamal1984
  • 1383 Answers
SOURCE: Cannot startup XP if connected to the 1T Buffalo HD
set first device as your harddisk is bios.
When you power up the computer press F2 or "del" key to enter in bios.then go to boot option then set first boot as hdd.
Posted on Jul 13, 2009
Crankstart
  • 696 Answers
SOURCE: My Buffalo drivestation 1TB was working ok until I switched pc of
Hi Sandra,
From the sounds of it you powered off your laptop while the Buffalo drive was connected.
If this is the case you have most likely damaged the partition and possibly a small amount of the data on the drive.
If you don't have anything crucial on the drive you should be able to go into Disk Manager and reformat it, this will make it usable again.
If you have files on the drive you cannot afford to lose then you will need the help of a data recovery pro, but this type of failure is pretty simple for them to recover from in most cases.
Comment back telling me if the data needs recovery or not, if it does, include you Country, State and City and I will refer you to an appropriate Pro, if not let me know it's ok to format and I will provide you with the steps you require.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
SelfHelpComp
  • 146 Answers
SOURCE: When I enable TurboUSB, it turns off my ext hd
yes..that is predictable..most externals can not take the boost without a firmware update. check the buffalo site for a driver
Posted on Dec 05, 2009
lock123
  • 6831 Answers
SOURCE: Buffalo 1TB drivestation beeping and not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Lenovo H520s Desktop windowsxp drivers
install the Intel HD Graphic Drivers from intel web site or us driverspack solutions
Feb 08, 2013 | Lenovo H520s Desktop Computer; Intel...
When I turn Buffalo 1TB drivestation on for first time and go to My Computer, it will not open window and freezes computer.
1st of all try it in another PC, and see if it does then same. Then we can establish if it's the drive station or the PC.
Unified IT Systems Ltd
Jul 21, 2012 | Buffalo Technology 1TB DriveStation...
1tb usb hard drive with "file system damage"
try replacing all the leads that attach the hard drive to computer
Jul 25, 2010 | Buffalo Technology 1TB DriveStation...
The hard drive constantly bleeps
try to reseat the memory first, its usually the one causing bleeps in pc.
Mar 29, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Dec 05, 2009 | Buffalo Technology 1TB DriveStation...
Hi Sandra,
Chris
Jul 16, 2009 | Buffalo Technology DriveStation HD-HC500U2...
My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Chris
Jul 16, 2009 | Buffalo Technology 1TB DriveStation...
Jul 13, 2009 | Buffalo Technology 1TB DriveStation...
Time for physical format ???
Did you fit the drive into the Buffalo drive case? If so, take it out and put it in your computer tower/case and format it from there. Then put it back into your Buffalo case.
Go to the Buffalo sight and see if your Drivestation needs a firmware update - there may have been bugs in the one you purchased.
Mar 14, 2009 | Buffalo Technology 1TB DriveStation...
Buffalo Technology 1TB DRIVESTATION COMBO TURBO EXT USB20 FW400 SATA 7200RPM USB 20 Hard Drive Logo
182 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
