Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
Hoover steamvac deluxe
The solution will not dispense from the machine but will still dispense from the hose.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=565323
Hoover SteamVac deluxe
Posted by stripes9 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have 2 problems, #1. The trigger assm may be loose or broken and is not releasing the solution from the water solution tank or #2. The valve under the water solution tank could be shot or broken. If so, then the water solution tank is one assm and you would need to purchase a new or a good used one to replace. Please, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 30, 2008
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
I have a Hoover steamvac ultra. The handheld hose
If you have installed the hose properly, try to hold your hand over the suction end with the cleaner on to prime the water in the hose. There is no way to dissasemble the hose. You could have a possibility of a few thing that have failed,
1. the pump that feed the hose
2. the valve on the hose end
3. the check valve where you connect te hose to the machine
Also verify that you are dispensing solution to the floor, if so, then the above needs to be checked.
Have it looked at at repair shop for diagnosis
Oct 09, 2009 | Vacuums
Hoover Superscub attachments won't work
It sounds to me like you have the water hose plugged in, but not the hose block. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. If you have already done this, then here is your problem: when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" your tank is now ready to pick up the dirty water from your hose. let me know if this helps!
Aug 06, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a hoover steamvac dual v and is leaking, bristels not working very food only two are speaning and is not sucking any water Very little solution comes out, or comes out in streaks when pressing the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=634728
I have a Hoover SteamVac
Posted by albazo on May 30, 2008
I have a Hoover SteamVac Dual V and it is leaking, bristles not working very well and only two are spinning and is not sucking any water
Very little solution comes out, or comes out in streaks when pressing the solution dispenser button on the handle. I think the lines may be stopped upped.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have a couple of brushes that are broken – the brushes are and assembly unit and would have to replace the entire brush assembly, and you are correct that the suction part of the vacuum is probably plugged up. You can take a wire hanger and use that to try to clear the clogged opening, but to be honest you may have to disassemble the vacuum and clean it entirely and replace the brush assm and any type of belt if needed. Pleas, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 30, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The solution has stopped going out the hose. The hose seems to be deep inside the machine. How do I get to it to unclog it?
The hose unhooks by the motor. But it could be the valve in the hose head. Maybe this picture will help:
Jan 27, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
309 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
