Question about Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER
Setup a linksys wireless router, unable to access admin webpage using 192.168.1.1, and reset button didn't work either.
    Brigadier General:
  • 10,406 Answers
Use an Ethernet cable to connect between one of the LAN ports on the router (not the WAN port) to the network-port on your computer.
On your computer, click Start
Click Run
Type CMD
Press ENTER
Type IPCONFIG
Press ENTER
Look for a line of output something like:
Default Gateway . . . . . . . . . : 192.168.32.1
Start Internet Explorer
Click Tools
Click Internet Options
Click Connections
Click LAN settings
Click to remove *ALL* the check-marks.
Click OK
Click OK
Take that '192.168.xxx.yyy' IP-address, from above,
and enter http://192.168.xxx.yyy into the input-area.
You should now see the router's "login" page.
Posted on Aug 19, 2010
I have a linksys E2500 and I need the password
You could try to connect to your router with a CAT5e network cable. Then open your browser and open the webpage http://192.168.1.1
When prompted for your username and password, try password 'admin' (without quote marks) and leave username empty.
If that doesn't work, reset your router and configure all the options over again (make sure you have all required information for the settings). For more information, look at this knowledge base article: kb.linksys.com/Linksys/GetArticle.aspx?docid=6af0fc7147664d2eaef47a2189a1ffce_E2500_FAQs.xml
Nov 07, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
I am unable to reset my Linksys WAP2000 despite using the reset button.
Hi mdouglas471,
If your resetting your router make sure that the router is turn on and you need to press and hold the reset button at the back of the router for 15-30 seconds using a Pen or Paper Clip. And for you to make sure if the reset was successful you can access the router settings page.
To access your router you need a working computer connected to the router then open a Browser then type 192.168.1.1. the username is blank and the password is admin.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Feb 03, 2011 | Linksys WAP2000 802.11b/g Wireless Access...
I lost the cd that came with my router (G-wireless WRT54G2). I managed to reset it and its working with ethernet cables but i want to go wireless with my laptop and playstation3 and secure it so no one can...
Good day,
You can use your Wireless Connection by enabling it in your router.
You can access your Linksys router by logging in to its webpage. Look at your routers manual for its default configuration in accessing your router.Most router use http://192.168.1.1 or http://192.168.0.1
Username:
Password:
Should appear in your browser refer to your manuals deafault Username and Password most Linksys routers use:
username:admin
password:admin
you can enable your wireless connections in wireless settings page and don't forget to put password for your wifi for security, you can use WEP, WPA etc. so that no one can steal your internet through your wireless connection.
Feb 01, 2011 | Linksys Wireless-G WRT54GS Router...
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Need to find my password
1. Access the Linksys webpage
*To access the linksys gui
a. connect your linksys to the computer via RJ45 (ethernet cable)
b. Open internet explorer and on the address bar type 192.168.1.1
c. A pop-up will ask for a username and password
c.1 username and password is both admin
c.2 username admin and password blank
c.3 username blank and password admin
d. If none work reset the modem at the back of it there is a reset button "warning if you reset the modem it will be reset to factory setting and you need to setup your router again"
e. disable your computer firewall
2. Contact you ISP for assistance setting the Linksys
Nov 16, 2009 | Linksys Wireless-G Broadband Router
Unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Dec 21, 2008 | Linksys Computers & Internet
Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
