Question about Panasonic Televison & Video
How to change default input to AV1 when power up on Viera?
  • 901 Answers
Go to menu mode. Scroll the list of selections. Mostly in the settings you will find this option. THIS USER CHANGEABLE OPTION. Refer user guide also. You can even a select a desired channel, to get selected on the power on.
Posted on Aug 19, 2010
2 Suggested Answers
SOURCE: How to make AV1 input the default when switching
Thanks. Problem solved. I found the operating instructions and read them!!
M.J. Ramage
Posted on Sep 10, 2009
Cannot get speech from my DVD player
you are trying to reverse the dvd and it will not work
Apr 08, 2015 | Panasonic VIERA TX-L32E5B 32" LED TV...
AV1 input question
The TV probably defaults to the RF channels. If it is an analogue only tuner model then it will go to the last used/programmed RF channel.
Sep 04, 2014 | Televison & Video
Grey border down sides of picture while on AV1
Assuming it's not your device causing the grey lines, just change your aspect ratio settings. Each input has a different set of settings that you can change, so don't worry about messing up the settings on your HMDI 1 input for example if you change your AV1.
Jul 04, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My Panasonic Viera TX-L37U10B won't display my Sky+ picture when it is turned on. We have to opt for ''AV1'' every time the TV is turned on!!! Why won't it show my current Sky channel on boot up??
Because the default input is the antenna, not one of the external inputs. If you want it to be picked up at start remove all antenna cables and start the Sky receiver before starting the tv - this is because only when there are no signals from the antenna the tv starts to look at the AV inputs.
Jan 12, 2010 | Televison & Video
M.J. Ramage
Sep 09, 2009 | Panasonic Televison & Video
I can't work out how to change the default input Sony KV-24WX1U
Don't think it can be done,you'll have to change it manually or it should go to AV1 when you turn on the cable decoder.
Jan 08, 2009 | Televison & Video
On the symphonic tv how can I get it to swith the input mode. I am trying to set up WII
Menu go to video change inputs to which outlet you are using for External jacks For Example If you hook jacks to AV1 on back then change input in menu to AV1.
Dec 28, 2008 | Symphonic ST419E TV
A friend accidentally changed settings on my panasonic plasma model th42pa50a..now no picture..the panasonic logo appears on screen only
Press TV/Video button repeatedly on Remote Control as shown in below picture.
You will get picture in TV from all connected things like cable, DVD etc
Dec 01, 2008 | Televison & Video
Televison & Video Logo
239 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
