Question about Bosch Classixx WFC 2465 Front Load Washer
Power Surge. Dryer works. But not washer. Is there a reset button?
  • 92 Answers
Yes there must be behind the washing machine please rate my answer thank you : )
Posted on Aug 19, 2010
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
GE Harmony Washer and Dryer will not turn on after power surge
The control panels on both machines may have fuses that need replacing after surge or a component on the panels have blown due to surge.
Nov 13, 2013 | Whirlpool Washing Machines
The touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
Re: the touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
No there is not. If the touch screen is blank and you know that you have power at the outlet, then the computer module has been fried and will need to be replaced.
Possible reasons for a computer module going bad are most commonly due to power surges. If you plug in an outlet surge suppressor then plug your computerized washer and dryer into it, that will save you BIG $$$ over time.
May 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Model ATF6000751. Replaced speed control board a month ago when final spin failed. Worked fine until yesterday. Could something else be causing the board to go bad?
Power Surges. In my area we suspect that 70 to 80% of the repairs here are caused by power surges. They happen all the time, andyou do not have to lose power to have one. They can happen when you have lightning, windstorms or beutiful sunny days. You have to have a 2000 joule surge protector or higher on your washer, refer, microwave oven, and gas stove or dryer if you have them. For your washer , gas dryer, and refer you have to have a rectangular box wall mount surge protector. You cannot have a power strip surge protector on a cord as moisture can get into it and cause electrical fires. I have seen three major fires caused by power strips behind washers. Lowes and Best Buy sell wall mounted box surge protectors with a 2150 joule rating that have 3 plugs on each side that rotate from front to the side so that you can plug your refrigerator into the side and not have the refer sit out from the wall any more. Good Luck, Appliance Specialists.
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Power surge and breaker went off, turned it back on and washer comes on but not the dryer, is there a reset button
The dryer is on a different circuit as it is 240 volts. Look in your breaker box and find the breaker for it (it should be tripped half way). Turn it completely off and then back on. There is no reset button for it. Make sure the plug is securely pushed all the way into the outlet.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Nov 11, 2008 | Smeg WD16BA Front Load Washer / Dryer
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
197 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
