Question about Timex Watches
Replaced battery, now no beep or alarm sound - Timex Watches
    Genius:
  • 1,970 Answers
Mcdevito75 here, I believe those would have to be reset along with everything else, once the battery is changed all previous settings are lost.
Posted on Aug 19, 2010
  • 1 more comment
  • oledave Nov 02, 2010
    Explicitly set Hourly Chime function, no sound occurs.
  • Michael C. De Vito
    Michael C. De Vito Nov 02, 2010
    mcdevito75 here, I hope you have the exact manfactures recommended battery installed, if not get the exact battery needed. Contact Timex at 1-800-448-4639. If you installed the battery yourself double check your work, make sure all buttons are hitting the quartz mechanism inside the watch, remove the new battery and re-install, then go thru the entire setting sequence again, sometimes there"s a second battery to operate the alarm and chimes, this 2nd battery is under a cover just under the back cover of the watch, this cover is the speaker for the chiomes and alarm.
  • blondpuddyta Nov 15, 2010
    Make sure the spring is still in tact. I read that the spring sticking out is key to the sound components.
Timex expedition compass, alarm does not sound since battery replacement.
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot...
Mar 01, 2015 | Timex Watches
Victorinox Chrono Classic XLS MT Watch
the problem is the battery it has way to much power. usually alarm clock use alkaine battries or energiezer they are best made for things like alarm clocks
Mar 14, 2014 | Victorinox Watches
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 | Watches
Lost the beep on my timex watch alarm
Try taking the back off and orientating it the other way (i.e. turn top for bottom). You don't have to screw it down to see if this will work. As soon as the back clicks in you will be able to hear beeps as you press the buttons
Mar 18, 2010 | Timex Expedition C45981 watch
My Luminox Alarm Chronograph seems to work in all respects but the alarm doesn't beep, nor do I get a beep when I set the alar. Might it be the battery??
It can be the battery if your watch model has separate battery for alarm function. If your watch originally is running on one battery, then check out if the sound transmitter spring is missing. Sound is transmitted through the coil spring or small peace of metal which is sticking upwards out of movement, so, when the case back is fitted to the case, the spring is touching sound membrane inside the case back, thus enabling transmit vibrations (sound). If there is nothing as I just described, you will need to get one and fit it to the movement. If there is such a spring, then movement has micro electric fault and should be fixed. In both cases you have to visit your nearest watchmaker and ask for help.
Rate me, plz.
Jan 12, 2010 | Luminox Watches
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
New Battery but Alarm sound doesn't work
Mar 16, 2009 | Timex Expedition 84601 Wristwatch
Timex 1440
You probably lost SPRING COIL while changing battery. It connects movement to sound membrane. See watchmaker to sort this.
Oct 25, 2008 | Timex 1440 Nylon watch
Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
Aug 28, 2008 | Timex Digital Expedition watch
Watches Logo
153 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
