Question about Samsung SyncMaster T200 LCD Monitor
I have the proper driver installed but the monitor will not show any display.
    Brigadier General:
  • 10,406 Answers
Connect the monitor to a different desktop/laptop, to prove that it is capable of working, at least some of the time.
Connect a different monitor to your desktop computer, to prove that your computer's video-card is working.
Posted on Aug 19, 2010
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
I have a Compaq Presario 5420 computer and bought
You'll have to update your drivers for your video card by going to the Mfg. website and seeing if they have any later drivers than you're currently using. In my case, the 1440x900 monitor was recognized when I downloaded later updates, though upon initial installation it wasn't recognized. My card is an ATI from about 6 years ago.
First, we'll try setting the correct screen resolution. Go to an area of your desktop that has nothing on it and right-click with your mouse. Select the "settings" tab. See if your monitor is described properly in the drop-down box. If not, you may have to install drivers for it to get the proper resolution. Take a look at the slider and see if you can slide it to the proper native resolution for your monitor.
You can always try uninstalling the current driver. Go to control panel | system, click on the hardware tab, then click on the device manager button, expand "Display adapters" then delete your default display device. The best then then is to reboot Windows and let it find your display adapter. Possible that it will boot into the proper resolution, but if not, follow the above directions again, but this time don't delete the driver, instead right-click and select, "update driver." Let's see if that works for you.
Nov 28, 2009 | Compaq Presario 5000 PC Desktop
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
Display wierd
if your display is not proper then check out that all your drivers are installed properly or not.
usually what happens that a person install wrong driver.
you can also set your display setting through java runtime. or by control panel.
Mar 14, 2009 | Samsung 2243BWX Monitor
I cannot install Dell E196FP monitor properly - resolution poor
The problem is you don't have the display adapter driver installed (Video Card)
You can net that driver at support.dell.com
Jan 25, 2009 | Dell E196FP 19" LCD Monitor
New 17" monitor, display is wide and short, not proper proportion
The monitor should have came with an installation or drivers cd. Use this disc to install the monitor specific drivers for your operating system. If you do not have the cd then you should be able to download them from the support section of your monitor manufacturers website. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | E-Machines 17" Widescreen Flat Panel LCD...
I HAVE A 22"HP MONITOR WITH 1680 X 1050 RESALUTIONS.IT'S ONLY SHOWING 1280 X 960.HOW DO I GET IT TO 1680 X 1050?
check the cd that comes with your monitor and install it and change the resolutions or check the display drivers that installed properly
Oct 01, 2008 | HP Computers & Internet
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
Image not displaying properly
Before assuming it's the monitor, try it on another display card.
It is possible that there is a problem in the configuration of the display card, or a defect in the display card.
Is there a computer service place, or a monitor sevice center near to where you live. You can then take the monitor to have it properly checked for you.
Jerry G.
Jun 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Need help installing
most people I have seen have to change the resolution in the display settings area of windows. after they do that the display will show properly without distortion
May 03, 2008 | HP Pavilion F1703 17" LCD Monitor
Samsung SyncMaster T200 LCD Monitor Logo
126 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
