Question about Refrigerators
Need to find defrost timer - Refrigerators
    President:
  • 1,891 Answers
To find the defrost timer i need your brand and model # .. some are inside the fresh food area inth back behing the control panel . other's ore behind the toe grill . mm
Posted on Aug 19, 2010
I need the compressor to run for a longer period of time. what do I do? Does the defrost timer has anything to do with it
Yes, when the defrost cycle is running the compressor isn't. Defrost timer should run a defrost cycle twice a day. Interval is 12 hours, defrost usually takes 20 to 30 minutes. Some cycle the compressor backwards slowly to warm the evaporator and melt the frost faster. I had a commercial walk in freezer that defrosted every 2 hours and had an evaporator heater element. The timer switches off the compressor and turns on the heater.
May 01, 2016 | Paragon 8145-20 Defrost Timer
Defrost timer does not advance after defrost
During this time of defrost you manually advanced into, Did the heater turn off them self? If they did the defrost thermostat does work, if the heaters stayed on the entire time (1hr) than the thermostat needs to be replaced as well as the timer. The thermostat is a cut off device to prevent the over heating of the freezer and liner (safety device). Think of a defrost timer as an egg timer, this timer runs regardless of function just advances like a clock. The thermostat turns off the heaters when they reach a temp rather then time. I hope this answered your question, good luck
Aug 17, 2014 | Refrigerators
Freezer needs to be defrosted every 3 to 4 days
Let's Try turning the defrost timer clockwise slowly. 67001036 Defrost Timer The defrost timer is item location 12 in this photo HERE and there should be a hole with a plastic plug covering the hole that you place the screwdriver through. Turn timer with a flat head screwdriver slowly until the compressor and fans stop. With fans and compressor stopped for up to 30 minutes the defrost heater should come on. If doing this causes the defrost to take place simply replace the defrost timer. If not then please let me know and I will instruct you on how to change the=> 67001794 Defrost Heater Assembly and the 12001937 Defrost Thermostat Thanks Sea Breeze
Jun 28, 2013 | Refrigerators
Freezer works but fridge does not
Lets see if the defrost timer being turned clockwise slowly will force defrost and cause things to get colder. On page 5 of the (click HERE=>ET4WSKXKQ02 Parts Manual ) you will see location 4? That is the 2188371 Defrost Timer
inside the fresh food com[partment at the top and behind the control panel will be the 2188371 Defrost Timer If forcing defrost solves the cooling problem then just replace the 2188371 Defrost Timer and if not we will need to check the 2176942 Defrost Heater Assembly and the 2192096 Defrost Thermostat Don't buy ba defrost thermostat until we discuss a different way of getting one to work should you need one (last resort because of cost) My focus is defrost timer and defrost heater at this point you will not need all the wires on the defrost thermostat should you need one just splice a simple defrost thermostat into the wiring harness. Below is a short movie on testing the defrost heater or click HERE Talk with me and we will get this refrigerator working, Sea Breeze
Refrigerator Defrost Heater Test
Refrigerator Defrost Thermostat Test
Apr 01, 2013 | Whirlpool Refrigerators
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Hotpoint side by side, freezer cold and frosty. Frig side not cold??
Signs of a defrost problem. Inside the fresh food section and behind the light cover you should see a small opening that leads to the defrost timer. Turn timer clockwise slowly until compressor and fans stop running. Leave everything in this position with fan and compressor not running for up to 30 minutes. Defrost should be taking place during this time inside and behind freezer rear wall.
Listen for signs of crackling or hissing coming from freezer. If after 30 minutes the defrost timer does not restart compressor and fans on its own then again slowly turn timer clockwise until they do start. If you need to do this you will need to replace the timer=> WR9X489 Defrost Timer If the timer is not the problem then the next two parts just may be the problem. The=> WR51X443 Defrost Heater Assembly that comes with a defrost thermostat as a kit. Let me know how you do with the defrost timer, Thanks, Sea Breeze
Jul 12, 2012 | Hotpoint Refrigerators
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
Everything in ref freezing up
1)check the temperature setting.it should be set on normal mode. 2) check if the ventilation in the fridge are blocked .there are two possibilities you will have to check 1)the defrost timer 2)the evaporator coil. How a common frost free defrost cycle works and the main parts. When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor. Defrost timers:
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
the evaporator coils are located at the inner side of the freezer section.if the ice gets collected in the coil and the evaporator fan stops running then the inner system of refrigerator will get over cool and this problem happens.
now to solve the issue .if to check evaporator coil is faulty or not there is a system.just unplug the unit from main power outlet then wait for 24 hours.then replug the power cord in the main power outlet.in 24 hours all the ice collected in between the coil and anywhere will get melted and then check out.if it works properly the problem was ice in coils.but if same problem then defrost timer needs replacement,you can get new timer friom
--- www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
