Question about Briggs & Stratton Garden
How do you drain the oil on a murray 201011X99B walk behind mower
  • 3,740 Answers
Is that your mower model number or your engine model number? Most smaller Briggs and Stratton engines the user's manual will tell you to drain the oil out of the "oil Fill hole." If you pass along the engine model number off of the air shroud I can look that up and confirm that for you. I will post this as a solution but if you need more assistance just respond here and I will gladly answer all of your questions.
Kelly
Posted on Aug 19, 2010
Murray 21" 6.0 walk behind mower. Plate showing model number is missing and I need to find a manual, model comes with grass collection box and a mulcher. any ideas please?
hi go to google search and type in... pdf murray 21'' 6.0 mower manual ......it should take u to a page with all the info u need .cheers
Sep 16, 2015 | Garden
My Murray 20" 3.5 hp classic throttle free design
it possible snap its main rod if it freely spins no compression buy new motor
Jun 08, 2011 | Briggs & Stratton Garden
I need a replacment drive belt for murray quattro 40 briggs and stratton self propelled mower model 20615x51a
hi
please find web site for parts and id of your belt
http://www.partstree.com/parts/?lc=murray&mn=20615x51A+-+Walk-Behind+Mower+%282000%29
part number is ref number 28 in the diagram
& murray pt number 037x99
partstree site is good site
cheers paul
Aug 07, 2010 | Briggs & Stratton Garden
Need to know where you drain the oil at on the push mower???
Todays walk-behind mowers are designed to drain the oil right out of the fill tube. Position you catch pan beside the mower and tilt the mower over the pan.Be sure the air filter is on the "up"side. Once all the oil is drained uot add the proper amount of oil,let the mower set for a few hours and you're good to go!
May 17, 2010 | Garden
What kind of oil do I use and how do I hange the oil? I have a walk behind mower model HD4QN20RF.
you use 30HD only 20 oz.. There is a drain plug under the deck in the bottom of the mower. It takes a 3/8 " ratchet and an extension. Push the handles down, Disconnect the spark plug wire, Mower the blade to one side, Take out the drain plug, put a container to collect the used oil under the mower, Put the mower back down, And it will drain the oil. Check and make sure you are getting the oil in the container. When it has drained the oil, Put the plug back in, put new oil in the mower. Hope it helps.
Good day.
Oct 17, 2009 | Garden
HELP, 2007 Toro walk behind mower
There is a drain plug on the block of the motor usually it looks square. if its not behind the blade on the under carriage, then it will be on top above the blades were the motor is visible. you may have to tip the mower on its side to completely drain all the oil. but the plug is always going to be on the motor either on the side or on the bottom. if the plug is on the bottom were the blade is remove the spark plug wire first. a mower can start if you turn the blade by hand and that would be vary bad news so always take the spark plug wire off and make sure it can not come in contact with the spark plug before going underneath the mower.
Jul 30, 2009 | Garden
Replacing the self-propelled belt on my Murray mower
Here is the link to the parts list for your mower. Though it doesn't give instruction for replacement, it does show an exploded view of the components:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-22646X92A-WALK-BEHIND-MOWER-(1999)-PARTS-LIST.pdf
I hope this helps...
Good luck
Jul 15, 2009 | Garden
I've been given a Craftsman Eager 1 6.5hp mower (front wheel drive)and I can't locate the oil drain plug.
On a walk-behind mower, the oil drain plug can usually be found on the underneath side of the deck. The drain plug usually has a square head.
Jun 23, 2009 | Garden
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Need a owners manual for Scotts walk behind Model 21595X8B
Good luck....Scott's was manufactured by Murray originally, then Murray went bankrupt, then Briggs bought the remnants of Murray. The Murray website only covers manuals back a few years. About the only way to get older ones is if someone has one for you to copy.
May 05, 2009 | Garden
Garden Logo
131 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
