Question about Maytag M7Q08F2ACOM Air Conditioner
My Maytag M7Q08F2A-E works fine but the remote circuitry has failed. Arthritis prevents me from operating controls on the unit. What part no. do I need to get a replacement remote or a programmable universal remote and who do I get it from?
  • 2,272 Answers
Part: crc112150010007. cost $35, The remote is at present out of stock.But you can place the order so you can get it when it comes in stock by few days. You can get this remote from:--click this link. http://www.appliancefactoryparts.com/search/partinfo.php?partsID=284212&modelsID=131433&typeName=air%20conditioner Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Posted on Aug 19, 2010
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
Maytag wall unit does not cool well
Maybe it's time for a new and more energy efficient unit. Those window units are cheap, but waste plenty of energy. Try a mini split!
Sep 03, 2013 | Maytag M7Q08F2A Thru-Wall/Window Air...
Therabath stopped working
So I opened up mine as it had stopped working and saw that there are two thermostat switches on the underneath. When the temperature heats up, the thermostat switches are supposed to open up. but at room temperature they should be close which means if you put a check for continuity across the terminals it should be a short ckt. The 05 NGT thermostat was fine. the 03 NGT 54N thermostat is definitely blown. I am trying to see if I can get a replacement part from NGT Controls. Not much circuitry in there but two thermostat switches. Hope this helps.
Apr 02, 2012 | Therabath Pro Paraffin Wax Arthritic...
My therabath died today, no power going through it....
Mar 21, 2012 | Therabath Pro Paraffin Wax Arthritic...
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
JBL Radial Remote Doesn't Work
Unfortunately, this is a fairly common problem with many small consumer electronics. The way that the devices are manufactured, there is an IR receiver that is soldered onto the PCB inside the unit. Sometimes this circuitry fails. There aren't any options on the Radial that would turn the option the remote off. Your best bet is that if the unit is still within the return period of the store you purchased it at, to return if. If it is outside of the return policy, I would give JBL consumer line a call to get the unit serviced, or get a replacement. Good Luck!
Jan 25, 2009 | JBL 6-1/2\ Round Coaxial Speaker By...
Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Jul 21, 2008 | Panasonic PV-8400 VHS VCR
Sound problems
I'm not like an electrical engineer or anything, but it sounds to me that there are some problems with the circuitry that operates the sytem (the circuitry in the subwoofer/built-in amp inside the subwoofer). As for the volume control, have you adjusted it from the remote and from the controls right on the front of the subwoofer? If you only tried adjusting it from the remote, then you probably need a new remote (if you can get a new remote; I don't think most remotes work with Durabrand). If you tried adjusting it from the controls on the subwoofer unit, then the subwoofer's circuitry probably needs to be replaced.
May 12, 2008 | Durabrand HT-3915 System
Maytag mmv1153aaw ehaust fan turns on
Normally the hood / exhaust fan comes on when you turn it on, or when the temperature at the bottom of the microwave gets high enough to close the hood thermostat.
Sometimes a failure of the hood thermostat or on the control board can cause intermittent or unintended operation of the hood fan.
A thermostat can only trip so many time before it fails permanently.
One way to test it is to unplug one wire from the thermostat, tape it up to prevent it from shorting, and see how it acts for a couple of days.
If it stops failing, the hood thermostat is bad., If it continues to fail, chances are you have a failure on the control board, which we can repair for $39.95 in most cases.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
DNX7100 Remote inop
The problem I had was with the remote control unit for the steering wheel controls. It shorted out. The head unit was fine. But, when the sterring control unit is shorted it also prevents the hand held remote from working.
Jan 01, 2008 | Kenwood DNX7100 Car Video Player
Maytag M7Q08F2ACOM Air Conditioner Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
