How do I override the Permanent Hold feature?
  • 455 Answers
Hello Push RUN PROGRAM botton.
Posted on Aug 19, 2010
How to set clock timer to over ride?
Rotate override knob located above dial.
For permanent override, remove trippers from dial
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Gene
Jun 28, 2014 | Intermatic Malibu 300W Power Pack...
When setting my timers should the manual switch be left in the on or off position?
Either position is fine.
The override is not permanent ON or OFF since it moves back and forth when trippers pass.
The trippers push a lever back and forth that opens and closes electrical circuit.
When the lever moves back and forth, it also clicks the override back and forth with audible sound.
If the timer is ON, you can move the override to OFF.
When the next ON tripper rotates around, it will move the override back to ON.
So the override just temporarily overrides the timer function.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jun 21, 2011 | Intermatic T104 24h 208-277v Mechanical...
What purpose for the toggle switch under the deck??
Per the DS1 manual the toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position.
Jan 28, 2011 | Fellowes DS-1 Shredder
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Why is yellow light blinking on top of unit?
Per the DS1 manual the yellow light relates to the SafeSense feature. A toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position. The SafeSense yellow light turns on when you touch or are too close to the paper insert opening.
Jan 18, 2011 | Fellowes DS-1 Shredder
How do i set a hunter theromtate #441100. i don't
Set the temp you desire and hit "Hold temp" or "program overide"
Hunter thermostats are notorius for problems.
Whenever I have a customer that is unfortunate enough to be stuck with one I always reccomend they replace it with a "Honeywell" or "White Rodgers" brand T-sat.
What kind of problems you might wonder?
Every kind imaginable.
If yours is not holding the set temp when you tell it to, it's probably not you, 99% chance the thing is simply malfunctioning.
Aug 29, 2009 | Heating & Cooling
Honeywell TH8320U1008
simply push cancel. That clears the hold feature.
Pushing hold once gets - permanent hold.
Pushing hold twice gets - days of permanent hold. So you can set it if you are going away on a temp and at the end of the days it goes back to normal operation.
Jul 21, 2009 | Heating & Cooling
Printing not clear (its so Blur)
Perform these operations:
  • Test->Diag->Clear->NVRAM
  • Test->Diag->Clear->CalData
  • Then re-calibrate the printer.
Procedures:
  1. Turn ON the Tech Access feature (hold ENTER and LINE FEED keys depressed approx. 5 seconds - until printer "beeps")
  2. Turn ON the Fault Override feature (hold ENTER and FORM FEED keys depressed approx. 5 seconds - until printer "beeps")
  3. Press the MENU key then UP Arrow to Offline - Test Menu
  4. Press ENTER then UP Arrow to Test Menu - Diag
  5. Press ENTER then UP Arrow to Diag - Calibrations
  6. Press ENTER then UP Arrow to Calibrations - Print Engine Cal
  7. Press ENTER and follow the instructions on the display
  8. Turn OFF the Fault Override feature by holding the ENTER and FORM FEED keys depressed until the printer "beeps"
  9. Turn OFF the Tech Access feature by holding the ENTER and LINE FEED keys depressed until the printer "beeps"
Mar 18, 2009 | Tally T6218 Matrix Printer
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
