Question about BenQ FP71E 17" LCD Monitor
Monitor Randomly Turns Black
Randomly, my Benq monitor's screen, which is working just fine will just dim in brightness and turn to black. The power button is lit up blue, not orange, so I know it didn't fall asleep, and nothing I do fixes this, until I turn the monitor off and wait for a while and turn it back on. Turning it off and on immediately only results in receiving the BenQ slogan for a short time, and then the screen turning black again. At first I had thought the problem due to possible overheating, but after leaving the monitor off for approximately eight hours (before any problem arose), and returned, the monitor operated fine for about five minutes before reverting back to that wonderful black screen. Is there any way to fix this?
  • polarb May 07, 2008
    When i press the power switch of the monitor, the button lit blue as per normal, however the image shown lasted less thn 1 second and the screen went black. The button did not turn orange hence it's not sleeping for sure.
    I press the switch twice to off it and turn it on again, the same thing occurs.
    I'm at a loss. I checked the warranty period and mine has just passed the 3 years mark.
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
Posted on Apr 02, 2009
Have a look at this site, a chap there had the same problem and fixed it himself.
http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
DonP
Posted on May 04, 2008
    Champion:
  • 220 Answers
The problem is with the Inverter PCB.
Contact Benq ,Company offers a 3 year warranty.
If Benq is not able to help please provide feedback.
Samir
Posted on May 03, 2008
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
I have a Compaq presario cq60. when i turn it on the screen is very dim. can c it with flashlight. works fine just very dim. hooked it up to external monitor it works perfectly. what is the problem he
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 06, 2013 | Computers & Internet
My LCD screen stopped working. Playing a game when the monitor was blackened. This time the screen is black. If I start the monitor, the led is orange, if I connect to my PC led color turns green but does...
victorash02, Is screen black n blank, or just black? Do flashlight test! Yes it could be both! Most likely problem with unit's internal "switch-mode-power-supply"/"CCFL inverter supply". You or technician will need to investigate for probable cause of black screen of death. Need a little history of unit! Did it work just fine 2 weeks ago? How many "ON" hours of use on the unit? When was it made? Did you PROVE that PC not cause and works ok? Get back here with more info so we can help.
12fixlouie on fixya. Read my fixya profile for a little while.
Mar 09, 2010 | BenQ FP71G 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
1,401 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
