Question about Kenmore Elite 45986 Front Load Washer
Need to flush hose that goes to coin filter due to mildewed water sitting in it
  • 530 Answers
Take the kick panel off.
remove 3, 7 millimeter screws
the lkick panel will just come off
in the very center you will see the pump filter untwist it and you will find your treasures.
I hope this helps
Posted on Aug 19, 2010
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Need diagram to re-install culligan module 4428-45 serial 322938
If you have not changed the other filters then they need to be changed also. The system should be sanitized before you re-install the filters. The Membrane goes in with the large rubber seal at top of filter housing. Place inside the head of module until it seats and reinstall housing over it.
1. Drain the tank completely
2. Take all the filters out
3. Add 1/4 tsp household bleach to each housing, turn water back on to fill housings, let it sit for 15 minutes.
4. Flush the bleach out completely.
5. Re-install filters
6. Flush/empty the storage tank 2 x before using water.
RJ
Dec 17, 2010 | Culligan Under Sink Water Filter
Water outlet fault. The door wouldn't open, so I drained the unit and then the door opened. I cleaned some coins out of filter and tried again. Same fault, water outlet fault.
Hello and welcome to Fixya. With the Asko washer it is possible to have some coins and debris up in the hose which goes from the tub to the pump as well as downstream of the pump in the drain hose, it is a pretty small diameter and quarters, nickles, dimes and pennies can block it up entirely. It will require a very thorough check. You may in fact have a damaged pump as well. If you watch the pump impeller it should spin freely, if it just sits there with the impeller moving slightly back and forth it is faulty. In any event you'll need to either phone in a pro or remove the pump and hoses ( which are held by one-time clamps ) which will require installing new hose clamps and removing the lower service/access panel. Depending on the actual model of Asko washer you have the process of doing this will vary. Let me know how you make out or if you require further assistance. Thanks for visitng fixya, please rate this info accordingly or please let me know how I can help additionally. Good luck. Macmarkus :)
May 25, 2010 | Asko Washing Machines
IS NO SPINING AND I HAVE ERROR 20
The problem is a clogged coin trap. The coin trap is located below the front loading door near the right front side. To gain access is the problem. It is in a bad location and this will take a couple of hours to fix at a minimum. Tools needed, a phillips screwdriver, short handled perfered. A large set of channel locks. A set of flush cutters. Purchase a couple of hose clamps to replace the cheap factory ones. Unplug the machine. Disconnect the hot and cold water lines. Remove all water from inside the washer. Turn the washer on its side. Looking at the bottom you will see a black rubber device, with a grey hose (the drain)running into it, a white device hung onto it, and the top of the corrigated black rubber device is attached to the bottom of the drum. Disconnect all connections. This is not fun. Remove the black unit. Look down inside the unit and you will see a clear cylinder (usually filled with coins and lint) In short the clog which is not allowing the machine to pump out its water. Clean the unit and keep the coins for your trouble. Reinstall the black unit.(coin trap). Make sure the green clamps are properly seated or better yet replace them with the hose clamps. If you are unsure about the sizes take the coin trap to the local car parts store and purchase a couple. Make sure the rubber parts are replaced flushly or the repair will leak and you will get to fix it again, after swimming in a bit of soapy water when you sit the unit up again. Reconnect the hoses and power plug. Run a short cycle and check for leaks, by removing the back of the machine and checking for water leaks. Good luck!!!
Jan 18, 2010 | Frigidaire ATF6000ES Front Load Washer
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water Cooler - Water has mildew taste
I just put about six cups of white vinegar (not diluted) into the reservoir and let it sit for about an hour. Then I emptied that out and flushed a few pitchers of very hot water through. It seems to have worked quite well.
Jan 09, 2009 | Hamilton Beach Water Cooler with Storage...
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
