Question about Avaya Lands Phones
Page causes phone to ring rather than come through the speaker
What "page" are you using?
If it is a button on another phone that "pages" just your phone. The button is programmed incorrectly on that other phone. If it is the "page" button that pages all phones, do all the phones just ring?
Posted on May 29, 2008
Cannot hear my callers on the zte majesty, speaker feature is nice and loud, pandora is fine. Just phone to phone conversation,
Refer to manufacturer technician locally. Suggest speaker replacement. Vacuums ruin speakers. !!Danger!! Do not blow or vacuum speakers. The cause is coil displacement possible electronic disconnection.
Sep 18, 2014 | Cell Phones
The comdial digitech 7714s in the back office does not ring. The phones in the front. There is no on off ringer switch as there is on the executech. Can't find FAQ in the manual I downloaded
I believe the ringer volume is low or at minimal or turned off, that's why you don't here any ring. Try this; press the arrow (left and right or up and down button) on the phone constantly. This should increase the ring volume if actually it is low. Or, call the phone with another line, while the comdial digitech 7714s is ringing and press the arrow buttons without picking up the phone.
Try this as well;
  1. Press optionS
  2. NEXT (twice)
  3. RING
  4. Then UP or DOWN to choose a ring tone
  5. Press SPEAKER to set.
Let me know if this doesn't work, so that I may direct you further.
Good luck.
Apr 04, 2011 | Comdial Impact 8124S Corded Phone
C118 not ringing, on selecting loud on alert, gives feedback on vibration.
hi,
try to check maybe your phone is in mute mode or the volume is set too low.
if playing also ringtones, games or your phone doesn't rings when somebody calls you, this could be the problems below.
if it is not in mute mode then most likely it has a defective speaker or loose connection to the speakers. you can check its connection if inside if you can open your phone. but try only opening your phone if you know what you are doing, you might worsten its problem. you can locate the speaker inside, it is like a small speaker and check if it has abnormalities. other than that, don't touch anything else.
(if you have a multi-tester, you can check the speaker itself by placing the red and black probe to each terminals of the speaker and if you hear a scratching sound on the speaker then your speaker is good. if none, then an open defective speaker.)
(WARNING: only open if there is no more warranty on your phone cause opening it can cause your warranty to be void)
dont forget to rate me. Thanks...
bst rgrds
John
Jan 05, 2011 | Motorola Mobility KRZR K1m Cellular Phone
No ringtone no sound in speaker . i can receive call
Your ringing speaker may get damaged.You can open the cover of your phone and just press hardly where the ringing speaker is situated.Then check with any ringing tone if the ringing speaker is working or not.If its work you can contact a mobile phone service center and tell him to clean the connection of your ringing speaker and mother board.
Or you need to change the speaker to get rid of it
Sep 30, 2010 | Nokia 6230i Cellular Phone
My phone makes no sound when it rings. Some days it does and some days it doesn't. When this happens, the loudspeaker doesn't work either.
Your ringing speaker may get damaged.You will not hear in loudspeaker because when you on loud speaker its connect to ringing speaker to get you the voice loudly.You can open the cover of your phone and just press hardly in the top that your ringing speaker is situated.Then check with any ringing tone if the ringing speaker is working or not.If its work you can contact a mobile phone service center and tell him to clean the connection of your ringing speaker and mother board.
I guess it may help you.Thank you
Sep 30, 2010 | Nokia 3100
My external speaker will not work
Hi, what causes the phone not to be able to ring out is due to the ringer inside the phone that allows you to hear a ringing tone and can be used as external speaker too.it's bad.
You will need to replace the ringer inside the phone. When replaced phone will start ringing out and you can hear when it rings out.
have a nice day.
Aug 31, 2010 | LG Xenon GR500 Cell Phone
My wife dropped her moto w755 and now you cant hear it ring vibrate still works any chance of opening it up and replacing speaker
hi :) here i can advice u send phone for technician. cause moto much model has screw lock the housing,if no tool,u must give it repair by technician. cant hear the ring,cause of drop,normal is the speaker lose in the right position for detect with mother board.so,it cant ring :)
please give me rank if my solution useful,thanks..
Jul 19, 2010 | Motorola Mobility MOTO W755 Cellular Phone
Will not ring for incoming call only viberates
You should try to put it on only ring cause some phones have issues simular to yours.
Jan 31, 2010 | Motorola Mobility Adventure v750 Cell...
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
241 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
