Question about Whirlpool GEQ9800P Electric Dryer
Our whirlpoole gold dryer has a vibration that is getting louder. When you turn the tub there id one spot where you can feel the tub virate. what could be causing this vibration.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Aug 20, 2010
Dryer makes chirping noise really louder than noal
Answered already: Only ask one time please.
Mar 06, 2015 | Whirlpool Dryers
My 2004 kia optima driver side front make a roaring noise while its rolling
Sounds like you have a wheel bearing problem. Jack up the front end so wheels are off the ground. put your hand on the spring on the strut then turn the wheel with the other hand. If the bearing is bad you will feel the vibration/rough spot in the spring. Noise will get louder or diminish when you peed up or slow down.
Apr 05, 2014 | 2004 Kia Optima
I have mitsubishi Pajero 2003 which I bought second hand. my veihcle vibrates badley, I feel the viration around 50 kpm and it gets worse over 100 kpm. I feel bad vibration under my seat as well as on the...
Take the car in for a front end inspection. Also get tires balanced, tires out of balance can cause I really bad vibration.
For the Orange Light?? I am guessing its a Engine light, it will require to be scanned to find out why it shows up.
Aug 12, 2013 | 1995 Ford F150 Styleside Regular Cab
It has high vibration and rattles!
Sounds like you may have a tub roller or two with a flat spot warn on them. You will need to remove the top panel to look down on the drum rollers and check to see if there is a worn spot on them.
Nov 30, 2010 | LG DLE7177 Dryer
Removing gold toned grab bars and fixtures from old whirlpool tub
sometimes a plumber leaves an access panel to get at the drain and jets under the tub---it's usually small and may not be enough to get a body in---usually the grab bars are permanently glued or siliconed on a fiberglass/plastic tub....a cast iron, or other non-plastic type tub may have removable grab bars...look for access area, or you may just have to cut out a piece of the wall to look----or if you do find a small access panel, and can get a telescoping mirror to look back at the back of the grab bar underneath the tub, you will find your answer----or you could contact the original manufacturer of the tub, and they can tell you if the grab bars are removable....another solution is to coat/paint/sandblast the metal bars however you'd like them to be
Mar 13, 2010 | Home
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer - LER4634EQ1
check the idler pulley and the rear tub rollers first
May 31, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
