Question about Toro Garden
Instructions for how to replace a drive belt on a Toro Riding mower, Model GT2100-468-601? With Koeler twin cylinder engine.
5 Suggested Answers
  • 6 Answers
SOURCE: looking for drive belt installation instructions
type toro manuals,and it will get u a site
Posted on Mar 20, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
SOURCE: Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
Posted on Jun 19, 2011
How do I replace a drive belt on a toro ride on mower model CV18S
+check with dealer, the service manager may help cheers.
Jan 12, 2015 | Toro Garden
Drive belt runs off 42 Toro
HI, I have a Cub Cadet 50" cut I had a similar problem and I had to change the spring on the idler pulley it had lost tension and replacing it solved my problem. Not familiar with your mower but if it has the same principles as mine you might want to try that.
Jun 13, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Got a twin, model cv18s in a 1996 model 72104, serial6922659. starts to smoke on idle and just over idle, once on full sthrottle doesnt seem to smoke much but uses a little.
possible its bad cylinder rings, which cause the engine to burn oil. its not a huge problem. just keep an eye on the oil level.
Mar 06, 2011 | Toro Garden
I have a toro lawn mower. Model no. 20352. The drive belt came off the pulley. How do I reinstall?
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
468 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
