Question about Vizio VO37LHDTV10A 37 in. LCD TV
I can turn on the power but the screen is black
  • Vizio Master
  • 12,061 Answers
Nationalservicealliance.com/visio/VIZIO-L37HDTV.pdf
service and repair manual above..If you decide to DIY. Please follow the troubleshooting steps in this manual, to isolate the section, also there are the part numbers required to obtain the parts.
www.vizio.com/support/
Above is your Vizio support link. Contact them for spares and any advise.
This is a classic switchmode power supply, shutting down, the Video section, to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Posted on Aug 19, 2010
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
May 03, 2010 | Computers & Internet
Black screen and won't turn off.
press and hold the power button for 10 seconds. If all else fails, diconnect the power cable from the system. Then turn it back on.
Dec 26, 2009 | Dell Inspiron Mini 10 Notebook
Screen turns black
Consider up gradeing your Power Supply Unit.,Depending upon a low wattage PSU to power significant upgrades ie;High end Graphics Processor Units,is a sure way to a black screen.Check out Power & Cool.com.
Mar 20, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Westington LTV-27w7 HD black screen
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
loumargo@verizon.net
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Vizio VO37LHDTV10A 37 in. LCD TV Logo
238 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
