Question about Garden
I have a 1983 bobcat 743b that needs a new fuel filter. i have taken off the old one. how do i replace it with a new one? and are there any steps after replacing the old filter, like: priming the filter with the primer bubble? or filling it with diesel fuel before installing the new filter?
SOURCE: spear and jackson chainsaw. runs
OK - let's work through this. If you need choke all the time then the mixture is too weak when the choke is off. Putting the choke on literally chokes off the air supply to the engine by lowering a small shutter across the entrance to the carburettor. That means either there is too much air getting to the engine (don't see how!!) or too little fuel. So, how do we get too little fuel? You could check for this as follows;
- before we do anything tricky let's check the obvious things - is there a fresh fuel mix in the tank? Petrol does go off, especially if there is 2 -stroke oil added to it. If it's over a month old from the pump mix up a fresh batch. Is the idle speed set too low so the engine stalls when the choke is knocked off? You can see this screw to one side of the carburettor (you need to remove the top lid in front of the handle on the chain saw, and then remove the air filter to see it). Turn the screw half a turn clockwise to speed the engine up. Be warned - if the engine starts it will run faster than normal and that means the chain may start to spin around. Also - check that the chain brake is off (i.e. the safety lever is pulled backwards, and that the chain is free to move BEFORE you attempt to start)
- is the fuel filter blocked? To get to this, make a wire hook (e.g. thick fuse wire) and gently hook out the fuel filter that's sitting at the bottom of the fuel tank, and take a look at it (be gentle - you can damage the gauze if you are clumsy). Does the gauze look clear? I.e. if you dip it into petrol it will freely run into the filter and of course drain out when you lift it? If not, replace it.
- next stop - are the jets in the carburettor set right? I don't have a service manual for this (and I know the manual says unhelpfully "return for service") but basically you will have seen two holes on the side of the chain saw (below the handle) two small 0.8cm holes; one marked 'L' (for low speed) and the other 'H' (for high). Put a fine flat screwdriver down the L hole and feel for the slot of the low speed jet. Once engaged turn it out half a turn and this will enrich the mixture - if this seems to help and you can start the engine then adjust the L jet in or out until the engine is idling comfortably. If it idles too quickly then you can also turn down the idle screw (see previous paragraph).
- no luck still? Well, it could be fuel pump or a blocked jet in the carburettor but this really is a 'return to the service centre' task!
Posted on Jan 12, 2009
SOURCE: Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Posted on May 14, 2009
VtToolMan
  • 704 Answers
SOURCE: gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Posted on Aug 20, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3200 chainsaw on which I
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: Primer bubble
From the fuel tank through the carb back to the tank. Just like the fuel system I sent you Scotty.
In case a different Scotty.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 10, 2010
My husband is too proud to ask this silly question. But where/which one is the inlet valve and outlet valve on a bobcat 743b
There is no such thing as a bad or silly question. this is why were are here. Google is your friend in such cases
inlet valve and outlet valve on bobcat 743b Google Search
Bobcat Parts - Bobcat Company
landing.bobcat.com/parts/
  1. Cached
  2. Similar
By choosing genuine Bobcat parts, accessories and programs, you'll minimize downtime and maintain the performance, comfort and convenience that are built ...
Bobcat Parts ' eBay
www.ebay.com/bhp/bobcat-parts
  1. Cached
  2. Similar
Find great deals on eBay for Bobcat Parts in Heavy Equipment Parts and Heavy ... KUMAR BROS USA the Kubota Parts. ... Fits Models:743, 751, 753, 763, 773.
Bobcat Parts ' Hydraulic Pumps, Motors, Engines, Starters, Alternators ...
https://www.loaderpartssource.com/bobcat-parts
  1. Cached
Items 1 - 10 of 9691 - We offer a variety of Bobcat parts including pumps, drive motors, and engines for your machines. Shop Loader Parts Source!
Used Bobcat 743B skid steer loader parts - EQ-20841 ' All States Ag ...
www.tractorpartsasap.com/used-bobcat-743b-parts-p/eq-20841.htm
  1. Cached
  2. Similar
Bobcat 743B skid steer loader salvaged for used parts. Item EQ-20841. All States Ag Parts gaurantees used parts for 1 year.
Skid Steer Parts Superstore AllSkidsteers®
stores.allskidsteers.com/
  1. Cached
  2. Similar
AllSkidsteers® is an online skid steer parts store specializing in Bobcat® skid ... Fuel Cap for Bobcat® 630 631 632 641 642 643 645 730 731 732 741 742 743 ...
Bobcat Parts
www.bobcatpartsonline.com/
  1. Cached
  2. Similar
Please contact your local Bobcat dealer for all product & parts related purchases or questions. We do not sell parts from this site and do not have access to ...
Jun 22, 2017 | Washing Machines
86 Bobcat with a Mikuni/Solex 28-32DID SA32. Starts and runs after 5 minutes dies like there is no gas getting to the engine.Put a kit in it which included the Float and Needle and seat assembly.
Craig, make sure you pushed the seat all the way down. it sound like if you put a kit in it and it is doing what you are saying my guess is the seat isn't down all the way. causing it to starve for fuel. you might be sure the fuel lines and fuel filter are good. sometimes by replacing fuel filter and fuel line it will run as good as new. cheap fix doesn't cost that much while your on the fuel system.
Dec 26, 2016 | Bobcat Garden
Fuel pump 1983 280zx
Hi Angela,could be a clogged fuel filter or a bad fuel pump,Here's a link showing you how to replace the fuel filter. Repair Guides Routine Maintenance Fuel Filter AutoZone com Here's another link to a new fuel filter. Duralast Fuel Filter FF651DL ReadReviews onDuralast FF651DL Here's another link on how to replace the fuel pump,change the filter first. Repair Guides Gasoline Fuel Injection System Electric Fuel Pump AutoZone...
Oct 31, 2016 | 1983 Nissan 280ZX
How does the fuel system work on a 873 bobcat
first replace the fuel filter, if that doesn't fix the issue, then perhaps you have compressed springs in the fuel pump, or debris in the tank blocking the fuel pick up.
Mar 06, 2015 | Bobcat Garden
Bobcat trouble shooting
Hello Angie, Check the fuel filter. Sometimes when the fuel tank is run dry, the sediment on the bottom of the tank gets sucked up by the fuel pump and clogs the fuel filter.
Sep 06, 2014 | Garden
Bobcat 773 fuel system
I found help when I purchased the repair manual for 10 bucks.On line downloaded the entire official thing and saved time with many basic issues. Forum are fine too. No need to pay Bobcat or anyone else big money for a 20 year old manual,
Jun 11, 2012 | Toys
How to change 2002 2.8 4bj1 fuel filter
your diesel engine should have a center bolt holding fuel filter it in place.you place drain pan under fuel filter when you remove top center bolt while holding fuel filter then remove old fuel filter then take new fuel filter add few ounces clean diesel fuel in new fuel filter lubricate gasket new fuel filter cartridge then install new filter crank engine check for leaks.
Nov 13, 2011 | Cars & Trucks
I have a bobcat 743b that seems to lack power on lift especially when it heats up
you might to get new batteries the might have been charged and discharged to many time
Jan 12, 2010 | RTO Construction Bobcat by Woody Click
Garden Logo
167 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
