Question about Symphonic SC519DD 19 in. TV/DVD Combo
I recently got this tv from my church. Everything works fine except it only goes to aux and ch.2. I have no remote and there is no menu or set up button on the tv. So how do I make it go through all my available channels
  • 901 Answers
It is difficult without remote. Try through the buttons provided in the TV front. Try the MENU button. Scroll through you will be able to get a solution.
Posted on Aug 19, 2010
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Dvdplayer shows its playing but not on tv does tv need to be programed
guest,
how is your hook up? is the dvd plugged into aux in or video in ...okay is the tv on ch 3? use remote press CH down to see if you have video/aux ch...3..2..1..video.....(if you are plug into video/aux) if you have a vcr do not disconnect...we do not wish mess anything up...
May 12, 2010 | GE 27GT271 TV
I have remote control no. RM-C754. I can always get Ch. 34, except for last eve. When I push the Menu button, it is all in Spanish. How do I get it changed to English, and then how can I get Ch. 34?
On Menu Look for Lanuage change it to English and then Look for Auto program for channels reprogram so it will lock on channels that it can pick up
Feb 15, 2010 | JVC Televison & Video
Cannot get lower channels
this is a chennel SKIP fuction . set any ch. to out of the tv memry .so you are reset this ch. pls open tv menu sysem and select edit ch. function .
if your tv ch.no.4 is blocked [skip]. set edit ch no:4 see this ch. is SKIP ON if yes then reset to v- or v+ [or arow key] to set SKIP OFF see this ch. no:4 is view perfactly
if your problum is not solve. pls infom me with your tv brand name and Model no.
Oct 07, 2009 | JVC AV-27230 27" TV
B/W Picture Only.........No Color
Maybe the menu set-up got adjusted somehow. Use the remote or on TV menu buttons and go to picture using the ch+ and ch- increse the color. I hope it's that simple.
Sep 23, 2008 | RCA 27V530T 27" TV
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
No remote - can't get tv off of aux mode
most zeniths change just the channel up or down takes if off video/aux. Its usually below channel 2. otherwise need remote
Jan 08, 2008 | Zenith C13A05LG 13" TV
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Symphonic SC519DD 19 in. TV/DVD Combo Logo
113 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
