Kenmore Wahing Machine Motor Overheating
We have a Kenmore 110.209224990 top loading washing machine with the three speed direct drive motor. It is about 8 years old. My wife had washed 3 loads when on the third load, the washer stopped in the middle of the agitate cycle. My wife noticed it had stopped, she tried turning it on and off again. It made a humming sound and she notices a strong burnt insluation smell. She then unplugged it. I looked at it later in the evening, plugging it in and it ran fine through the rest of the cycle.
The next day I took the front off and ran it with just water. After about 15 minutes, the motor windings measured 160 degrees F and still rising. Before I replace the motor (or the machine), I want to know if there are any other (less expensive) things that could cause the motor to overheat.
Thanks, Steve D.
...same problem here. any answers?
Posted on Jan 07, 2010
  • pauldelange7 Apr 11, 2011
    ...also same problem here - any updates - what did you guys do?
Wash machine runs fills with water drains but will not spin to wash or end of cycle but I do hear motor running
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Feb 08, 2011 | Kenmore 15864/15862 Top Load Washer
Not doing anything, making a ratchetting sound, won't wash, spin,rinse, anything
Have you checked the drum for residue that may actually prevent it to spin? try to check the cycle selector as well and try to load more clothes... keep us posted, thanks for using fixya!!
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
I have a Sears & Roebuck, Kenmore top loading washing machine Model 81864120 that will not Agiate or Spin. It does fill and drain with no problem and the timer for the wash cycles work fine.
Sep 08, 2010 | Kenmore Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore model #23922 washing machine won't spin
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
May 14, 2010 | Kenmore Washing Machines
Slow agitator in Sears Kenmore 800 Series washing machine
The other shaft on the motor directly drives the pump. .
Jan 19, 2010 | Kenmore 15864/15862 Top Load Washer
I have a kenmore elite HD king size capacity top load washing machine. Model # 11022932102. Machine fills but when cycle begins agitator doesn't move and hear loud clicking noise. water pumps out but no...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22932102
The "clicking" is llikely the prongs hitting each other if the rubber center piece is destroyed.
Jan 16, 2010 | Kenmore 23822 Top Load Washer
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
I have a top load Kenmore washer. The bottom agitator will not moveand feels as if it is froze up. The top agitaitor moves just fine. The machine will fill and drain fine. When the agitator should be...
Dec 20, 2009 | Kenmore Washing Machines
Kenmore top load wash machine heavy duty super capacity . It spins out alot of the water but clothes are still very water as if the speede isn't fast enough to spin all the water out.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts. Look at the section containing the motor and transmission.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
Oct 15, 2009 | Kenmore Washing Machines
Washing Machines Logo
297 people viewed this question
Top Washing Machines Experts
