Question about Durabrand PDV-709
Power cord for house
Where can I get a new power cord
  • 33 Answers
You can buy an ac power charger adapter for your Durabrand PDV-709 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Posted on Dec 19, 2008
  • 77 Answers
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
How to replace pull cord
take the 3 screws out of the housing they should be 10 mm or 7/16 or if it is really new try 3/8 Sockets take the cover off and you wil se the plastic housing tk the Screw Out of the Middle And you will see the Whats left of the cord tk it out and replace it with the new one and put it back in put th screw back in and before you but in back together turn the housing to you r Left And wind up the cord and put it in and away you go pull
May 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
POWER CORD
Yes a power cord is something readily available at any ACE or equivalent stores, electrical, HVAC parts houses too.
Mar 08, 2012 | Duracell Digital Camera Battery Charger
Dog chewed power cord. how do I repair
assuming this is a window air cond? It is not safe to use electrical tape, duct tape or any other kind of tape on a power cord to cover bare wiring. Many times I have cut the cord short enough to cut out the place where chewed and gone to a hardware store where I can get a new cord end that matches the wall plug and wire it in to the shorter cord. If this is not possible, you will need to either make a new cord or try to find a cord at an appliance supply house.
Apr 09, 2011 | Haier Heating & Cooling
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
How to install a new power cord on a tristar vaccume
You must flip the Tri Star upside down to reveal hidden body screws. Generally 2 at back near the wheels and one at front below the cord retainer.
Once removed the body will separate at the bumper. Before removing the motor , note the position of the carbon brushes relative to the body housing. They will be offset allowing the housing to close without striking the motor.
This is a metal vac body, your connects must be clean and should be taped after using twist terminals as a precaution. Your cord will go first to the switch, then power runs from the switch to one side each of the power head and motor, then from the opposite power head and motor lead back to the switch.
You should secure a knot inside the body of the vac as a strain relief so the cord cannot slip out after connecting
Sep 09, 2009 | Vacuums
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Throws the breaker,,i installed a new cord and plug
Check to make sure that you have it wired correctly almost sounds like you have the positive and the negative on the machine crossed with what your house is
May 28, 2009 | Galaxy G14-AT Popcorn Maker
HAD TO CHANGE FROM 4 PRONG TO 3 PRONG AND NOW DRYER RUNS FOR A
When you connected the new cord, did you make certain to connect the line 1/2 wires to the Line1/2 input's, and the Neutral to Neutral inside the wiring compartment?
Not heating up almost sounds like the heating elements are not getting their full 220 VAC, but then if you had something wired wrong in back, a breaker should trip. Make sure you've connected the new power cord correctly at the input power point. I am guessing this problem occurred between the time that you had it at the old house, and the new house, with the power cord changeover.
Jan 22, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Lost Power Cord cant find a new one
I lost my power cord for my Electric skillet and called Wal-Mart number on the back of the skillet and they said it would be able to be exchanged for a new skillet with a cord if purchased within 2 years even without a receipt or a box :-)
Aug 05, 2007 | Rival S16 Electric Skillet
Durabrand PDV-709 Logo
88 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
