Question about Microwave Ovens
Microwave turntable does not turn
Hi I have a Sanyo above range microwave model EM-S8000W that has a turntable that does not turn. It makes a lot of noise like the gears are grinding. The turntable turns freely in both direction by had. I would suspect stripped gears.
Would you know if this can be repaired and where I could get parts for this.
Thanks!
AJ
  • 2 more comments
  • startle69 Jun 21, 2008
    I have the same problem with the same model - just happened yesterday. I'll post back if I can find the part. It is a synchronous motor part # KX63MY2AS
  • arlle Jul 10, 2008
    Sanyo Microwave, Model: EM-S8000W, turntable motor replacement or substitute for KX63MY2AS synchromous motor.
    Has anyone been able to locate as replacement?
  • HEMETEER Dec 09, 2008
    SANYO MODEL EW S80000W MICROWAVE MOTOR 6172222226-- NOT AVAILABLE
    SUGGESTED REPLACEMENT F3265G60AP BY GDBARON APPEARS OVAL IN SHAPE, ORIGINAL MOTOR IS ROUND.. YOU QUOTED 14.99 AND THIS ONE IS 22.99...SO, I AM RELUCTANT TO ORDER IT... SANYO PEOPLE GAVE THE ABOVE PART NUMBER WHICH DIFFERS FROM OTHERS IN THIS SITE WITH SAME OVEN.. CAN YOU CLARIFY FURTHER GDBARON?
    THANKS MUCHLY....
  • markajolley
    markajolley Oct 01, 2012
    Here is where you can buy it.http://microwaveglasstrays.com/shop/120v...
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
Posted on Aug 01, 2008
I have found the only known replacement from MartinMicrowave.com
Here is a link ton the replacement motor : http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-kx63my2as-p-425.html
Posted on Jan 29, 2011
  • Microwave Ovens Master
  • 8,973 Answers
The turntable motor has failed. The part number was 6172222226 (or 617 222 2226) but unfortunately it is listed as no longer available.
Unless you can match it up visually with one from a local appliance parts store, it's best to disconnect and insulate the motor lead wires.
You can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
How do i fix a sanyo microwave
call ser. tch. ur motor might be spoiled already . its a added function mabe of the unit if ur turntable motor not wroking so does ur microwave
Feb 21, 2015 | Sanyo Microwave Ovens
Light comes on and turntable moves but not cooking Model EM-G4775S 900 watts
Fuse blown? Needs to make high voltage for the magnetron. A blown fuse usually means trouble in the high voltage system (a shorted HV diode or maybe a bad stirrer [metal fan-like device] bearing which is located just above the interior case under the waveguide assembly). If suspect, replace the stirrer as a unit. If fuse looks ok, maybe bad door interlock switch or not being operated by door closure.
Aug 03, 2009 | Sanyo Microwave Microwave Oven
Turntable doesn't spin
Well the table might not be on the revolving piece- that is what happened to my microwave oven, or the revolving piece might have to be connected to a belt inside that turns it
Jan 17, 2009 | Sanyo Microwave Microwave Oven
Turntable mechanism is not working
you will have to take it off the wall. There should be three screws in the cabinet above the unit . 1. unplug unit 2 place a large towel under unit to protect stove or cabinet 3 have someone support unit while u remove threee phillips screws 4 the back will hang on the wall rotate down lift and remove. the turn table is usually ran by a rubber belt and motor. Hope this was helpful please rate me
Jan 12, 2009 | Sanyo EM-S8000 Microwave Oven
SANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
http://sanyoservice.com/
Dec 08, 2007 | Sanyo EM-D1100 1100 Watts Microwave Oven
Microwave Ovens Logo
1,102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
