Question about Panasonic FP-7750 Black and White Copier
Change copy code
We have a used panasonic copier with a preset code which allows you to copy. How can we change that code?
  • 42 Answers
Larry, that depends on which model copier you have.
In order to help you I need the model #
such as FP7735 Dp150 D350 etc.
Posted on May 15, 2008
How to reduce the size of a color copy?
You will want to press the MENU button on your printer until the Change Copy Settings item appears. You will then scroll through that menu using the left and right arrows on your menu panel until you see the ENLARGE/REDUCE menu choice. This will give you 3 choices to enlarge or reduce your copy. There are Preset Ratio, ZOOM, or Fit To Page.
Preset Ratio has 2 different sizes you can choose.
Zoom allows you to choose from 25% to 400%.
Fit To Page will automatically scan your image and then fir it to the size of page you have chosen to load into your printer.
If you haven't already done so you can go to the following webpage:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Choose the MP210 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000), the actual link is called "mp210sosmwin110us.exe". Clicking on that link will allow you to download the file to your desktop. Then double-click the icon and your manual will automatically unpack and install itself. You will then see an icon on your desktop called MP210 series On-screen Manual. Double-click this to load the actual manual. Then choose User Guide. When the User Guide loads choose Changing the Copy Settings under the Copying heading on the left hand side. You can then see a detailed description of the information I gave you in this answer.
This should let you do your adjustment but if not please let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 15, 2011 | Canon PIXMA MP210 InkJet Printer
DAB preset is stuck on chanel 1. Machine will not allow DAB to retune or move to another chanel
Have you tried pressing the play mode button to change from preset to station list which will allow you to view all stations available.
Nathan.
Jan 14, 2011 | Panasonic SC-HC30 Audio Shelf System
Am used panasonic copier pf 7818 asking for a password
go to service mode USER PRESET key 3 A3 original size keys are simultaneously pressed . then F1 will appear presse key 5 and print 42 to 0
Aug 27, 2010 | Panasonic FP-7735 Black and White Copier
How to change devolper
Remove the waste bottle then the drum unit from the front of the machine.**Cover the drum unit so it is not exposed to the light.
Remove the Developing unit and empty the developer from the dev unit into waste bag. Once all the developer is removed...take the new bottle of developer and pour it all into the dev unit. Replace the plastic cover back onto the top of the dev unit. Re-install the dev unit back into the machine, then replace the drum unit back into the machine then replace the waste toner bottle. Close the front door. Enter the copier adjustment mode on the keypad by pressing "user preset,Orig size(Ledger), and Multi-copy key #3 in sequence.
Then press Multi-copy key #8 , then press the Print key.
Now select th code "09" and Press Print.
The machine will run for approx 2 minutes to initialize the new developer. Press Clear/stop and User preset to escape from the service mode. You are done.
Jun 07, 2010 | Panasonic FP-7750 Black and White Copier
Remove copying codes
F-5 service code 42 F5-42-0 set 42 to"0" no accounting,51-0 no copy account,52-0 no FAX account
To enter service mode,Function,copy, "3" simtameously default password 00000000 if changed willrequire a service technican who last service machine
Mar 30, 2010 | Panasonic Workio DP-1820E Copier
COPIES FROM PANASONIC FP7722 ARE JUST BLOTCHY GRAY
yep!
we can say it is common error/malfunction for these series of fp-77xx
it is also called as quarc error
you may fix it by manually adding some toner at the developing unit
or by pressing USER PRESET + 11 + 1 to perform manual add toner maybe up to 5x until you see some improvement.
Feb 15, 2010 | Panasonic FP-7735 Black and White Copier
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
How can I reset the key signal on my Panasonic FP-7722?
user preset button, original size ledger and the number 3 button get's you in to service mode, F1 go to F7 by hitting 7 and start button, touch 26 and start, change number value to 120,000 and hit start button. Exit service mode by hitting user preset button and clear button.
Sep 25, 2009 | Panasonic FP-7735 Black and White Copier
How to recharge some users of the ricoh af 3228C in the office?
Most Modern copiers have an access code system built in, this works in two ways, first it elimnates unauthorized copying as the machine is essentially locked if you do not have a code.
Second, It allows you to track the copies made by each code. By assigning each dept or individual with an acess code you can now track the number of copies each has made.
You will likely have to have the service tech come in to set up the feature and adminitrator functions. Once this is done you will have better control of your machine.
I have seen in larger operations a 20-25% reduction in copies once the codes are in place.
If the built in controller does not have enough access codes or features there are aftermarker products available.
Hope this is of some help
Ed
Apr 17, 2009 | Panasonic DP-8020E Black and White Copier
How to re-set so that "Another Original? No-Yes" does not display after making one copy
You can look in the user's settings. But, I have not seen that display not show or had anyone ask about it.
Feb 06, 2008 | Panasonic Workio DP-2500E Copier
Panasonic FP-7750 Black and White Copier Logo
80 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
