Question about Bosch Classixx WFL 2462 Front Load Washer
Bosch WFL 2462
Machine has new pump, but when filling for new washing cycle, it is draining the water out automatically. Eventually, the active light starts flashing. Have used troubleshooting guide in the manual to no avail. The old pump was noisy but still working, tried putting that one back on but problem still the same. Help! Laundry piled up to the sky!!!
Thanks
Chris Berry
  • Anonymous Jul 23, 2008
    Yes I have same problem . but have placed the outlet drain pipe high . at start of cycle machine drains and the auto cycle is very erratic working sometomes and not others, I has been staning in storage for aroud one year . but on testing machine find its not working correctly.
    I have checked the connections. and really cant understand the problem
  • andy tom Jul 23, 2008
    outlet pipe is high . as the water goes in the pump goes on also erracic cycles.
    President:
  • 1,294 Answers
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight.
Possible u didnt connect well after your pump job or ........
Posted on May 09, 2008
  • prem mathew May 09, 2008
    Pl rate..................
My washing machine is washing but not drainning well and not spinning well please help model classixx 1400
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 24, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch WFL 2060 UC Filling with water and then quitting
It is possible that during the transportation one or more of your harness connectors may have come loose. Unplug the machine and lie it on a piece of carpet or something similar(I like to use those brush typpe welcome mats) Look around and try pushing any connector that you can together. Best of luck,Dana
Jul 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Classixx WFL 2462 Front Load Washer Logo
181 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
