Question about Panasonic PT-60DL54 60" Rear Projection Television
Tv shutting off on its own.
I have had a panasonic DLP PT-60DL54 for about 3 1/2 years and up til now its worked fine. The first time I seen a problem the tv shut off after about 5 mins and a fast clicking sound was coming from the right side. The power button was blinking red and the lamp light came on. I unplugged the tv and removed the lamp. It looked fine so I reseated it and turned the tv back on. The tv worked fine for about a day and done the same again. It doesnt seem to matter if you remove the lamp or not. It works fine after it is turned back on again. There is no consistant time between failures, it could be 5 mins or 5 hrs. Does anybody out there have any ideas?
  • jasonxterra Nov 17, 2008
    same problem with mine. started 2 months ago. thinking about ordering a replacement bulb.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
Posted on Nov 25, 2008
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic dlp tv won't turn on the first time. If
The power on switch is faulty. It takes two or more presses to come on. Replace it if it irritates you so much. Else there is nothing wrong with the set.
Jan 11, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Nov 15, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
I have had a panasonic DLP PT-60DL54 for about 3 1/2 years and up til now its worked fine. The first time I seen a problem the tv shut off after about 5 mins and a fast clicking sound was coming from the...
This is an old posting, but will reply anyways.
I am not sure if this is the same problem that I had , but sounds similar.
I found that there were power surges, or lack of power. I could see my power bar blinking at the time this happened.
So after trying everything under the sun, I plugged it into another outlet with the power bar, and have never had a problem since. It seemed that for some reason I had surges in that line, and have no idea why.
Not sure if this is what is happening to you, but maybe might be of some help to someone else.
Thanks.
Bob.
Nov 21, 2008 | Panasonic PT-60DL54 60" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-60DL54 60" Rear Projection Television Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
