We bought a 32' akai lcd hd tv at Sams in NC and CA. We have had problems with both. We took the one back at Sams Club/California. I am in NC now and the one we bought for our place here just stopped working. It shut off and will not reset and turn back on. Have there been recalls on this tv?
  • samsquared Apr 11, 2009
    32'' Akai Model AKPHLCT3101AD will not turn on, red LED flashes when power on is pressed and then goes out..
    President:
  • 2,712 Answers
Yeah, we have had a few similar problems with not only this model, but most other projection TV's as well.
Try these steps:
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try this..if you unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $20 or so), or just change the faulty capacitors. You can make out which are faulty, because their caps will be swollen on top. Here's a pic
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 35V. however, if you dont find 35V, you could use a 50V as well. They will be slightly larger, but you should be able to get them to fit in.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each, depending upon the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
42 in HD LCD Vizio purchased from Sams club in 12/09. has no picture or sound, but can se a couple lights on in the back.
You will need a power supply replacement.
You can get replacement parts here:
http://www.shopjimmy.com/catalogsearch/result/?q=VX42L+
or ebay, or encompass parts.
The replacement is easy as you just take out the old and put in the new!
Thank you!
May 16, 2011 | Vizio VX42L 42 in. LCD TV
I bought this tv at sams club but didnt use it right away then Iused it for about 4 months then one day it wouldnt turn on at all please help me as Im unemployed
Take it back to Sams Club and explain to them what happened - 95% chance they'll exchange it because Costco in California does. I believe they are owned by the same company. Hopefully you still have the receipt.
Nov 18, 2010 | Televison & Video
Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to partsstore.com this is where I found the power supply board for this TV.
Jun 30, 2009 | Akai LCT3285TA 32 in. LCD Television
TV will not turn on from Stand By mode
if you are comfortable taking the back cover off, do it and visually inspect a cylindrical shaped components on the power supply unit... if you can send a picture please do s69joe@hotmail.com
Dec 08, 2008 | Akai LCT2715 27 in. LCD Television
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
Akai won't turn on
my tv burned up after 1 month it kinda did what yours is doing and we had to pay fo shipping and it was almost 100.00 dollars, it has been 6 months and we have not got are tv back and they dont know when we will get it so dont send it to these idots they dont car. im in the army and told them this i will be going to irac and cant get my tv. they said send it some where else. so if i where you take it back were you got it
Jan 17, 2008 | Akai LCT3285TA 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
No Picture
Hear say has it that Toshiba who made alot of the internal parts for this model can offer more help than Akai.
As for the other problems... first Id try leaving the TV unplugged for a day or so. This is a great TV, picked mine up for 400 from my boss who baught it a few years back for 1400 from Sams Club. If I hear a solution I'll be sure to come back here and post it.
Oct 31, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
