Hard drives failed
After reformatting drive D; the other drives can't be read anymore...
  • 558 Answers
Other drives most likely keyed off the drive was striped or raid con fig of some kind the data on the drives are lost as well if this is the case you can reformat them all and then load windows on the c drive typically the d drive is another cd rom or optical drive of some kind so I must assume you had mult Hard drives
Posted on May 02, 2008
Will reformatting my hard drive save it the disk from going out?
There isn't any way of fixing a failing hard disk (it is nearly worn out).
You need a new hard disk, but in the mean time backup your data regularly before the hard disk fails completely.
Dec 29, 2012 | Computers & Internet
How to fix a dead hard drive
Try a low level format. There is a strong possibility that your hard disk will no longer be able to perform normally even after a low level reformatting. Looks like a new hard disk is the answer.
Jan 04, 2010 | Maxtor Hard Drive
Way to retrieve files off an ext. hard drive gone bad?
try to install the drive as a secondary drive in a pc u know works (dont mix fat with ntfs drives) if there both the same OS u should be fine, see if u can access the files then, if u can great pull off what u want to keep & reformat the drive, if u cant well..........read this, i couldnt explain it any better
http://www.popularmechanics.com/technology/how_to/4294038.html
Dec 10, 2009 | Western Digital Computers & Internet
Recently purchased a Mac. Unable to transfer data or videos. Is Maxtor 3200 compatible with Mac?
Macs can read NTFS format used by PC's, but not write to it.
You will have to take all your stuff off the drive, reformat it on the mac, and then you will be able to read/write to it. But PC's won't be able to read it anymore, unless they install some special drivers
Nov 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
LaCie 200GB HD is now ''read-only''. Recommends reformatting.
>> my computer could not repair the hard drive
It seems that the disk-drive is "dying", and the "table of contents" on the hard-drive has become corrupted, and automated attempts to "repair" the corruption have failed.
>> the hd is being offered with limited functionality, basically read-only.
Yes. Take this as a "hint" that the disk-drive is about to "die".
>> It recommends that I back-up the info elsewhere
Good advice. Take the advice.
>> and reformat.
This may help -- it will identify any "bad" spots on the hard-drive, and will either permanently avoid using those bad spots, or it will allocate a "spare" track on the drive to be used as a substitute for the "bad" area.
However, even after doing this, I would not "trust" the device to be a "reliable" backup for my important files. Like a well-used chalk-board in a classroom, the disk is getting "worn-out".
If it's still under warranty, exercise the warranty.
If the warranty has expired, replace it.
Apr 22, 2009 | LaCie Computers & Internet
Takes a very long time to boot
try to replace your Hard disk. maybe your hard disk is damaged and need to be replace
Aug 14, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Restarting
before it start to do that was the computer freezing it sound you haqve problem with thr mother board check you power bar good luck cheers
Jan 18, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Driver problem
corrupt directory.
if you can read the data, remove it.
then reformat the drive.
if this is not possible, replace the drive.
sorry if the fix does not work.
mark
Dec 21, 2007 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
