Question about Intel Motherboard
Asrock p4i65g motherboard
I have a asrock p4i65g motherboard and a p4 3.06 cpu
i want to upgrade the boad and my be the cpu but dont know which will fit my case
i have the advent 3316 which the case is a d1 what ever that means
any help would be very thank full.
  • 1 more comment
  • shane500 May 02, 2008
    what is mATX form factor
  • Anonymous Aug 26, 2008
    i need  sound driver
  • Anonymous Jan 02, 2009
    i have this mother board asrockp4i65g and lost the disc now when i try to download the drivers for this they wont download
I`ve got a p4i65g motherboard and 3.0 cpu basically i`ve installed windows vista ultimate and the onboard audio does not work i`ve bin trying to download driver software but wont download them wat should i do
Posted on Jun 03, 2008
  • 32 Answers
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
Posted on May 02, 2008
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
No video with or without a new video card on an asrock p4i65gv motherboard
So you can no onboard video when using the onboard connection right? and no video using an external video card also right? In this case, the promblem lay with the motherboard/ram/cpu and not with your video card. Try resetting the bios via taking out your cmos battery or shorting the cmos pin to see if a miracle would happen and the system would post. If not and if you have another board with compatible hardware, then you can try testing out the cpu, the rams. If you hear beeps when starting up the system, try to take note of it and look up on the internet via what bios make it is, and decode the beep error for what is wrong. If you don't her any beep, the other way only to know what is wrong is having another compatible board to test your cpu/ram, or make sure the ram and cpu you are using is supported by the asrock motherboard. If you do have another board to test your cpu/ram and even the video card, and they work, then your motherboard is scrap and needs to be replaced.
Jan 26, 2011 | Asrock P4i65G Motherboard
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
Asrock P4i65G Motherboard Connections
Link
#26 is the Audio header for front panel
Jun 01, 2008 | Intel Motherboard
Motherboard is dead!
Here is a new board. http://3btech.net/asp4so47880p.html but you have 90 days to set it up & test it.
To answer you're question. (Yes it will fit). Both boards are Micro ATX.
Here are links for both boards showing their specifications.
Asrock P4i65G
http://www.dealtime.com/xPF-Asrock-Asrock-P4I65G-skt-478-i865G-800FSB-dual-ch-DDR400-8x-AGP-64MB-on-board-VGA-SATA-RAID-LAN-USB2-0
Asrock P4S61
http://www.dealtime.com/xPF-Asrock-ASRock-P4S61-P4-SIS-661FX-DDR400-Motherboard
This is ASRock's web site for the P4i65G
http://www.asrock.com/mb/overview.asp?Model=P4I65G
If I can be of more service, just post back & let me know how thing go.
Mike
Apr 28, 2008 | Asrock P4S61 Motherboard
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
ASRock P4I65G motherboard
The manual is here:
http://www.asrock.com/manual/P4I65G.pdf
See page 20 for the Clear CMOS jumpers..
a bios virus is a very rare animal.
Oct 14, 2007 | Computers & Internet
Intel Motherboard Logo
657 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
