Question about Pioneer AVIC-N2 Car DVD Player
Pionner n2 in dash tv
Do i have to have the hidaway box and 30 pin cable to turn it on
  • tony3711 May 17, 2008
    only have the avic xr1 head unit and wont power up, will i need the brain and 30 pin plug to power up?
Yes! iyou can get them on ebay , thats if you dont have one
Posted on May 12, 2008
Need to find wires for power lock &power unlock am installing a remote start these wires are for the power door locks on 2010 ridge line
If your 2010 Ridgeline is the same as the 2009, the wires colors and location are listed below;
Power Lock pink/black - MICU, green 30 pin plug, pin 25
The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. Meter this wire while pressing the passenger door lock switch.
Power Unlock pink/blue - MICU, green 30 pin plug, pin 9
Feb 08, 2011 | Honda Ridgeline Cars & Trucks
Aig No siginal
Sep 30, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Can the PCM be at fault for a 2004 dodge durango not starting? I attempted to start my vehicle after it had been operating fine all day and it will not crank, the gauges and all dash lights flash, the horn...
No , probably not . Do you know what a starter relay is ? It's located in the under hood fuse box ! That 30amp fuse sends B+ voltage an current to pin #30 , if you find an pull out the relay an look on the bottom you will see 4 sets of numbers 30 & 87 an 85 &86 . 30 is Battery voltage which when energized the relay will send this B+ voltage through pin 87 to the starter solenoid turning on the starter . You could take a jumper wire an jump those 2 pins an the starter should spin . Now , 85 & 86 are the control side of the relay ,Pin 86 should have B+ voltage supplied by fuse #32 10amp located in the junction block , maybe inside vehicle fuse box . Pin 85 is from the PCM , the PCM will supply a ground to this side of the control circuit if it see's a input from the park neutral safety switch . Do you know what that is ? Try shifting to neutral an see if it starts . Also if jumping pins 30 & 87 the starter doesn't spin . check the Positive battery cable using voltage drop . You may have a bad cable . Starter Voltage Drop
Mar 12, 2017 | 2004 Dodge Durango
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
Pioneer avic n2 screen keeps going blank
Hi. Sound like you have a loose 30 pins connector either at your monitor or hide away unit. Only the best service technician can handle that issue. Try to do it yourself or have some self taught tech to do it and I would bet you 10 to 1 that you will fry it. As a matter of fact the only one whose offer that service is Rick on Ebay. His store name is Same Day Audio Services. He is very reliable and all of his work is guaranteed. It will cost you about $100. If he can't fix it, he won't charge you anything. Good luck.
Mention Hogan from Utah and he might give you a discount.
Dec 23, 2008 | Pioneer AVIC-N2 Car DVD Player
Display not working
just got a tech bulletin from pioneer in my bulk mail(almost trashed it). they said its a recall on all avicn1 and 2's. the ribbon wire going from unit to screen fails after many cycles. they are issuing free repair.
Notice: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 To: January 3, 2007 Dear Valued Customer: Re: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 We would like to inform you of a potential service issue with Pioneer's AVIC-N1 and AVIC-N2, inform you of our plans to resolve this service issue, and ask for your help in notifying consumers. If a consumer is not experiencing any issues currently, there is no need for the consumer to take immediate action because the one-time fix to resolve the service issue will be available if an AVIC-N1 and AVIC-N2 later experiences the service issue. _Importantly, the service issue does not pose any health or safety risk._ Pioneer is aware of a potential issue with the flex-cable powering the flip screen to the AVIC-N1 and the AVIC-N2. After a number of power cycles, the cable has been observed to fail and cause the unit to malfunction (symptoms may include, but are not limited to, the flip-screen becoming blank) -- flex-cable failure can only be confirmed by Pioneer; standard service charges may apply for service issues not related to the flex-cable upgrade. This issue may affect almost all AVIC-N1 units and AVIC-N2 units. Please contact Pioneer at the number listed below if you have a question about whether your AVIC-N1 or AVIC-N2 unit is affected by this issue, or if a specific malfunction affecting your AVCI-N1 or AVIC-N2 is related to this issue. To address this issue, Pioneer is providing a one-time cable upgrade to consumers for their AVIC-N1 and AVIC-N2 at no charge to consumers for parts and labor. Pioneer will offer the free upgrade either upon request or automatically if an affected unit is serviced for another reason. Pioneer will exclusively perform the free cable upgrade for all units (i.e., no other service facility should perform the cable upgrade). If you own an AVIC-N1 or AVIC-N2 and you are experiencing the service issue, please contact Pioneer Customer Service toll free at 800-421-1603 to arrange for the cable upgrade. Pioneer service representatives are available Monday through Friday, 9:00 a.m. to 7:30 p.m. (Eastern Time). Customers who have paid for the cable upgrade are eligible for reimbursement of certain service costs if sufficient proof of service can be provided -- please contact Pioneer at the above-listed phone number for more information regarding reimbursement rules. Customers can also review FAQs regarding this service issue. Click here to view the FAQs. We sincerely apologize for any inconvenience this service issue may cause you, and we thank you for your cooperation and continued support of Pioneer. Sincerely, Pioneer Electronics (USA) Inc. *Pioneer Electronics (USA) Inc., 2265 East 220th Street, Long Beach, CA 90810* ------------------------------------------------------------------------
owner of
Motion Marine & Car Audio
the florida keys
Dec 08, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
The screm of navigation it blue on my avic n-2 pionner
Hi. I can fix you screen for $100. Email me at or call my cell 801-414-4566. Hogan.
Oct 16, 2008 | Pioneer AVIC-N2 Car DVD Player
My HDMI set top box display reads "no input signal" but everything appears connected. I have no picture or sound. Cannot access any tv stations.
Make sure TV is set to HDMI channel.
Try a different HDMI port on back of TV.
Reset the cable/sat box and reset the TV by powering off both and unplugging them for the wall outlet for 30 seconds. Turn cable/sat box on first, and then TV after 30 secs.
If this fails, check the TV manufacturer's website to see if they have any software upgrades that will resolve the HDMI issue.
May 26, 2008 | Televison & Video
Pioneer Navigation System
You will need a gps antenna, 30 pins data cable and an antenna extension to do basic installation set. For more precise set up you will also need reverse and speed signal sensor wires(pink and purple).
Nov 19, 2007 | Pioneer AVIC-N2 Car DVD Player
AVIC-N2 power harness go to the bottom of the page and click on order parts and just follow the white rabit down the hole and buy one
Nov 15, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
51 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
