Ilo V23DLWX I keep getting a code AVC on, AVC off. It will show a picture for a second then it will go to the AVC on, off thing. Help.
  • Anonymous May 07, 2009
    my lcd tv has sound but not video
  • 558 Answers
Your auto volume control needs to be set either on or off but you need to set it to make this go away
Posted on May 02, 2008
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
The unit keeps freezing up
Take out memory stick from camera and check does it still freeze?
I think memory card in camera is causing problem.
Hope this info will help you.
Dec 08, 2009 | Sony MHS-CM1 HD AVC Camcorder
The screen and the module both are showing red lights . The screen will not show a picture and I have tried to reset. Any options?
Press the VOL+ and Channel - button on the set and than the power button while holding the two buttons.
If the set starts then the fault is the error counter wich must be reset to 0. Max is 5 faults,if a sixth error is measured the set stops.
Nov 02, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Ilo LCT32HA36 won't show a picture but does have power
Hi, I had a computer monitor that acted similar one time and what I found were that there were some bad capacitors in the power supply board inside. They were identified by the swelled up rounded ends and the heat discoloration of them. They look like little aluminum cans with a vinyl sleeve shrunk around them with the component values written on them. A normal one is flat on the end with no signs of any leakage around them of a brownish blackish substance similar to wax or tar. They are relatively inexpensive at an electronics supply store($1-2 each) so I replaced them all. This will require some soldering and electronic repair knowledge though. The power supply could not stabilize so it just kept shutting down the picture that only displayed for a brief instant.
Good Luck!
Jan 24, 2009 | iLO LCT32HA36 Television
Cant find a remot for ilo v23dlwx-u12 flat screen tv
you may purchase a universal remote, (note , be sure it has setup & menu compatability for your particular brand ) or you may purchace a new or used original remote at www.remotes.com by entering your specific brands model number in the sites search field. hope this solves your problem in the most efficient manner!
Jan 01, 2009 | iLO 2600 Television
Can not program remote to TV
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON DON'T JUST PRESS IT ONCE LIKE A LOT OF SITES SAY TO DO.  I HAD TO PRESS IT A FEW TIMES, AND THEN IT TURNED THE TV BACK ON AND THE REMOTE WORKED!!! MY REMOTE WAS THE RCA RCR312W...TV IS AN OLDER ORION
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
May 15, 2008 | Tatung V23DLWX Television
23 inch Ilo LCD Tv Model # v23dlwx
You have a bad inverter board.
Apr 25, 2008 | Televison & Video
Is the iLO v23dlwx the same as the Tatung V23dlwx
www.polaroidsupport.com/polaroid/docs/FLM-3001ServiceManual.pdf
Nov 16, 2007 | Tatung V23DLWX Television
I can't get my iLO-2600 to completely work as a monitor.
The TV will always show as screen number 2 because the laptop screen will be found first. I use mine as a monitor for my Desktop.. However, for the picture to show what your laptop does you have to clone your desktop. The button should be where your screen properties are located.
Mar 03, 2007 | iLO 2600 Television
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
Electro Med Services...
