Question about Brother IntelliFAX 2800 Laser Fax
Intellifax 2800 I can fax out but cannot receive a fax. I can hear it beep and then it will say "call pickup". Any help will be greatly appreaciated.
I was having the same problem. I went into "receive mode" and changed it from Fax/Telephone to Fax Only and it seems to have fixed the problem.
Hope this helps you.
Posted on May 07, 2008
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Call pickup
I had the same problem. I went into "Receive Mode" and changed Fax/Telephone to Fax Only and it seemed to work.
Hope this helps.
May 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Can fax but can't recieve
your machine may be in mannual mode or in answering machine mode. First confirm weather your machine is in auto/fax mode for receiveing.put the machine in to fax mode with sigle ring pattern.
Receiving "Beep"
You might be able to lower the volume in the menu.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
2800 WILL NOT RECEIVE FAXES BUT WILL TRANSMIT
there sir your fax is may be in mannual receive put it in auto receive
Sep 18, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
231 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
