Question about Epson Stylus CX6600 All-In-One InkJet Printer
Paper feeder I have removed the paper jam from the printer, but it continues to jam repeatedly.
  • 2 more comments
  • Anonymous May 08, 2008
    paper jams in the print mode
  • nupe3 May 08, 2008
    Press the color button to feed the paper through but continues to jam under the print cartridge
  • Anonymous Jun 27, 2008
    I printed about 120 envelopes sideways and now A4 paper will not feed in but gets jammed. It is as though the feeder bit on the left side is not pulling the paper in at the same speed as the spooler on the right. Any suggestions? I have had to remove some jammed envelopes from the rear right hand side only so I wonder if this has caused it?
  • cloud51 Jul 11, 2008
    I have an epsom stylus CX6600. I have had paper jams in the past but alway managed 2 clear it, but today the paper keeps jamming for no apparent reason(definataly no obstructions in feeder...) Each time I retry, the paper seem to be pulled fasted to the left side causing the sheet to jam!!! Any help in this area would be greatly apprieciated...thankzSu
  • 61 Answers
You probably is working with paper excessively wet. Even when you cannot detect the moiture can be present in the paper. Try to use a paper dryer (there are for sale in computers stores). Dont use to leave the sheets in the printer when you are not printing, leave them in the dryer.
Posted on May 02, 2008
I have a 6600 printer I am getting a paper jam though this no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 29, 2011 | Lexmark C533DN InkJet Printer
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Printer is jamming paper and there is nothing there to be causing the paper to jam
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any debris or foreign objects. If you're capable and willing, you may carefully lift the printer upside down so that any debris in the feeder will just freely roll out. If none debris found, lift the printer cover and remove the cartridges. While the cover is open check for any obstructions in the paper path. If none, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again. If paper jam continues, please don't hesitate to contact Lexmark technical support for additional assistance.
Apr 21, 2011 | Lexmark X2500 All-In-One Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper jammed under roller small piece of paper keep saying jam e3
    Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
    Procedure:
    1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
    2. press [maintenance] repeatedly until <b> appears.
    3. press [black] or [color].
    4. repeat steps 2 to 3 twice.
    5. open the paper output tray.
    6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
    7. repeat steps 2 to 3 times.
    the sheet paper is automatically fed in and then out of the machine.
    have a nice day.
    Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
    Please try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 09, 2009 | Lexmark T644 Laser Printer
    Doc. feeder jam, after paper removed completely
    HP LaserJet 3030 All-In-One Printer
    Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
    Epson Stylus CX6600 All-In-One InkJet Printer Logo
    211 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
