My P4P800 E deluxe is now quite old and I have just installed a Prescott 3.4Ghz CPU. Are / is there any Bios update available that would supercede the CD Install as I would like to keep in the lead with this Machine.
  • labradts May 06, 2008
    Thank you, youre a Gladiator !!!
    There is a Box that is gettin into my face every time I boot up....
    It says, (Box 1) Floating Point Division by Zero.(Press OK)
    Then, (Box 2) Access violation at Address 0040C42E in
    module 'ASUSPROBE.exe Read off address 00000030 -(Press OK)
    Hell, all I wanna do is Record in my Studio, in the 4 years I have had this MB + 3Ghz Prescott + 4 Gigs of Ram and 3 Graphic Card supporting 5 Screens _ - - _ Never had a problen, figured maybe the bios needs update from the Jurasic period to now !
    I've down loaded an update - but it's in the form of 'ROM File' is
    there something missing cause I can't do much with it or do I drag 'n drop the files into system 32 ??? What? what? what?
  • 166 Answers
Hello there.
Please click
and select Bios then Bios utilities. On here you can update your bios. Please be aware this is not something to be taken lightly, If done incorrectly your motherboard will fail to function, so please be careful and read the information before doing anything.
Hope this helps.
Posted on May 02, 2008
  • Ryan Harron
    Ryan Harron May 06, 2008
    Glad i could help :)
  • Ryan Harron
    Ryan Harron May 09, 2008
    Hello again. I noticed a comment even though the solution was rated already.
    From your error its possible you have faulty RAM (memory) or more likely the Asus PC probe software has developed a fault, this software is used to read your computer's temperature and power.
    I suggest uninstalling the software from the add/remove software area of the "Control Panel".
    Then re-install the software either from the installation CD that came with the computer/motherboard, or download the latest version from Asus's website at the web address i posted above, under "utilities" called "Asus PC Probe".
    As for the bios updating, i would be hesitant about flashing your computer bios if you are unsure of the steps required to do so, if you haven't added any new hardware to the system and its erroring now, its most likely a software problem.
    Hope this helps.
Optiplex repowers when putting in hibernate/standby mode
Try sleep instead of hibernate. They never seem to work. Just an opinion.
Jan 11, 2013 | Dell OptiPlex GX620n PC Desktop
I get a pb with BIOS. I change the battery of BIOS and now I can not even acceded to BIOS : DEL doesn't run. I change jumper for ten seconds : not better DEL doesn't run. Yesterday the bios charged...
1 or 2 things going on here, I'm assuming the jumper was your reset jumper (Please refer to your motherboard manual for location).
Assuming you have reset the jumper and no Bios is either a dead CPU or Motherboard. You can normally test if the motherboard is bad if this does not beep (again make sure you speaker on JPR Configuration is correct if no motherboard manual please refer to URL :
Nov 23, 2017 | ASUS P4P800-E Deluxe Motherboard
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
Upgrade from P4 2.4GHz to P4 3.0GHz Prescott on P4P800
Sounds like the new CPU is bad. The only other thing that it could be is if there are some settings changed in CMOS. I would clear the CMOS and if that does not fix it then the new CPU would be bad.
Dec 09, 2008 | ASUS P4P800 SE (890552603657) Motherboard
I want to upgrade cpu on mother board p4p800
*********** board supports upto 3.2 GHz+ P4 CPU
Dec 03, 2008 | ASUS P4P800-E Deluxe Motherboard
CPU Upgrade on Biostar P4VTG
1. Try change PSU - 350-400Wt is recommended as minimum.
2. Try update BIOS to last version.
Nov 30, 2007 | Biostar P4VTG-A07 Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
