Question about 2wire Wireless-G 802.11g ADSL Gateway
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
  • W4bes Dec 31, 2008
    I have the same problem. Disconnected services with at&t & now have internet with Road Runner. Can I use my 2Wire modem to broadcast the wireless signal? Please help.
  • 298 Answers
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
Posted on May 05, 2008
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
I want use my 2wire (2701HG-B) Wireless Router without the dsl line
Modem and routers are considered only as access point you computer may be able to connect to your router but if you dont have a DSL line you will not be able to go on line... if you dont want a DSL line there are service that concentrates on wireless alone... in this DSL line are not required nor router but may provide you a USB wireless adapter that has their wireless service then again try calling an Internet Service provider for this options...
thanks... Roger
Jun 11, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Will a 2 wire dsl router 2701HG-S work with cable modem
No, not the way you want it to. The wan(internet) port on the 2701 is an rj-11 that will only connect to a phone line with DSL service. There is no way to use this as a router with your cable modem. You need a router that has an ethernet (rj45) port as the wan port.
Oct 05, 2009 | 2wire 2700HG-B Router (2700HGB)
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
May 15, 2009 | 2wire Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
402 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
