Question about Princeton Digital VL2018W Monitor
The black color of the monitor has green in it?
I have the oddest problem of green showing through when there's supposed to be black on the picture. I have no idea what could be causing this, but all the other colors look alright.
Someone please help!
Thanks!
  • Jwheel May 18, 2008
    Uhm, the video card is brand new. It's Dual GeForce 8600 GTS's SLI'd for best fps.
    your attempt is inaccurate. Thanks.
Check out your video card... probably its getting weak....
Posted on May 18, 2008
SOURCE: Colors not distinguishable
Try changing or replacing the display cable ....Simple as that... might work!
Posted on Nov 23, 2006
Benimur
  • 6966 Answers
SOURCE: colors
Hi, This sounds like a color driver problem with the RED. I will assume that the blue is good since yellow will only be present if the green and blue are both ok. Below is a copy of my response to a similar post at http://www.fixya.com/support/t181021-zenith_a25a11d_no_red_color "...If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem..." Hope this give too an idea. Good luck and pls post again how things are or if you need further information. Kind regards.
Posted on Aug 20, 2007
Rifaa
  • 99 Answers
SOURCE: monitor off color
I'm not sure on what u just said but I think u might be having a loose VGA cable connection where it meet the graphics card, just check it out
Rifaa
Posted on Nov 09, 2008
Matampong
  • 153 Answers
SOURCE: 17 crt monitor (BOKA)turned to green resolution
Try moving the VGA cord to the PC, faulty VGA cord displays such color problem.
Posted on Nov 27, 2008
  • 3940 Answers
SOURCE: My monitor is all weird colors
Generally, this is caused by the loss of one of the main color inputs (Red Green Blue). Do the Following:
  1. Check the cable connections at both the monitor and the computer. Look inside the connector for any bent bent pins (there may be some that appear to be missing, generally that is normal) then reset the connections firmly and tighten the retainer screw snug, but not extremely tight.
  2. If that doesn't resolve, try the monitor on a different system and see if the problem follows the monitor. If it does, try a different cable. If the problem doesn't occur on another system, then the video card of the effected system is suspect.
  3. If issue occurs on multiple systems with known good cables, then the monitor will need replacement.
Posted on Dec 21, 2009
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
The color in my monitor is not right its dont have the right color where its suppose to be red or black its mostly green
I also get the input not supported on my desktop. I have an acer. Sure wish i could fix this problem
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Color
check your cable
good luck
Sep 05, 2007 | Sharp LL T19D1-B (Black) 19" LCD Monitor
Princeton Digital VL2018W Monitor Logo
21 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
