Question about Dryers
After drying a load of towels, I opened the dryer and the heat coming out of the dryer was so intense that I kept the door open hoping that it would cool down. The heat was still as intense after 5 minutes after turning the dryer off. I was concerned about the heat so I unplugged the dryer, which then of course cooled off. It also seemed to take much longer to dry the load of towels. I am concerned that this dryer could be a fire hazard.
  • 78 Answers
IT IS A FIRE HAZZARD. don't use it again, leave it unplugged! there is a problem with the timer or worse. if it is an old dryer get a new one or a used one from a local appliance resale/repair shop. that's where you can get a good deal if you can't afford a brand new one.
Posted on May 02, 2008
Taking too long to dry
your lint trap and lint vent are most likely clogged. Easiest way to fix it is to move your dryer away and disconnect the lint vent from the dryer and then take a yard blower to the back of your dryer with a towel around the blower in the hole to ensure the max air moves through the machine. (Ensure the door is only slightly cracked or your house will get very dusty) then clean the lint trap. Then do the same to the lint vent line (make sure the opening of your vent line on the exterior of home is clear of any debris or critter screen) reconnect your vent hose and it should work as new
May 16, 2012 | Kenmore Dryers
Everythings dries fine in my Kenmore dryer except for towels. It takes 2+ hours to dry a load of towels. What could be the issue?
Make sure that the moist warm air from the dryer can escape from the room where the dryer is located and that the Lint filter is clean and, if fitted, the air control vent is fully open.
The dryer needs to get clean fresh air with little or no moisture tro work properly: opening window/door to let the excessive moist air escape will help.
Hope it helps!
Sep 23, 2011 | Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
The drum stopped spinning when it was drying a load of towels and will not start again.
I had the exact same thing happen. I was drying a heavy load of towels and jeans and it just quit. No tumbling, no heat, no air.
I took my dryer apart and found that there's a thermo switch on the duct between the fan and exhaust. When open, this cuts power to the motor (which I think also cuts power to the heater).
This is the part:
I made a temporary jumper past this and it started. So, I have a new switch on order.
Jan 04, 2011 | Amana NED7200TW Electric Dryer
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
