I have a problem with my wet2820 washer dryer but it will start a programme but as soon as it gets to the spin it freezes
    Scholar:
  • 58 Answers
Freezing is 1 of three things
1. door lock could not be actuating
2. motor has siezed
3. timer not advancing.
check those three
especially a dryer
im leaning more towards the motor
Posted on May 02, 2008
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Candy as108
IT has shorted out u will need to replace board
Aug 21, 2013 | Washing Machines
I have a Bosch WET2820 washer/dryer and if I am away from home for a week, water starts to assemble in the interior of the machine and the moisture starts to smell badly. I select the drain programme, but...
the water inlet valve is letting the water by, you will need to fit a new one. to get the correct part number you will need the model number which u already have and the "FD" number to get the specific model as there are a couple of varients. you should find the fd number on the silver rating plate inside the door
Nov 19, 2010 | Bosch WET 2820 Front Load Washer / Dryer
Hello, I need a manual for a washer/dryer - bosch wet2820. Thank you.
you'll get it on the net but you'll need to pay for it that's why i didn't got it sorry
Aug 26, 2010 | Washing Machines
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
DOOR
check your door .. door lock damage or doot pin damage
Sep 06, 2008 | Hotpoint Aquarius WD640 Front Load...
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
