monitor powers on. No CCFL lights are on, just the green "on" light. after about 5 seconds, the CCFL tubes flash (still with nothing on the screen) and then the whole thing shuts off. It will keep going through these cycles until the plug is pulled.
What is causing this?
Comments:
May 08, 2008
- Actually it was bad caps on the psu board. i replaced those and presto. Inverter boards are usually alright...it's the fact that if a cap is bad - it pushes WAYY too much power to the inverter causing the CCFL tubes to not come on.
-   Soyo 19" TFT LCD Flat Monitor, power light is on but screen will not display picture. if i push the power button off & on it will display the picture for maybe 2 seconds. picture is very dark. Can you help? -   happycatx2
Jul 05, 2008
-   I've replaced the suspected caps but still got the same blinking power indicator. 12 Voltsdc coming from psu line to video card. I disconnected psu and connected a 3 amp 12 volt dc external supply and the monitor works.
-   mertjonjan
May 20, 2008
-   when i plug the monitor in, the green power light comes on, then it flashes on and off nothing on the screen, until i unplug it-   Guest
