Question about Canon PIXMA iP1600 Printer
Colour printing Having problems with colours. tried deep cleaning many times also changed ink, no effect. When I print nozzle check I get no blue lines at all.I do get red (more pink) and yellow. Can this be fixed? How? Also, how can I stop this happening in the future? I use my Pixma very infrequently
  • elgnarc May 03, 2008
    That will only help when I've solved the current blockage problem. Any advice on how to do that would be gretaly appreciated - otherwise it will have to be new printer!!
    Scholar:
  • 154 Answers
1) use a printer (especially inkjet once a week
2) Sometimes in the printer settings you can adjust the colors , dont'know if this works with canon also .. it is usually in the advanced printer settings .
Posted on May 02, 2008
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Nothing is printing. It looks like there is no
Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
To print a nozzle please refer to chapter 12 page 115 of the manual,
If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
You can download the manual here:
http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
Nov 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
INK
download the utility ssc service from the site ssc.com and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Only prints black & blue
I have a similar problem - i can print all colours apart from red.
I've tried cleaning, deep-cleaning, and even bottom plate cleaning but of none if this improves anything.
Tried cleaning the print heads and nozzles with cotton buds, but this dont do anything. Even tried re-seating the cartridges but this does nothing either
Mar 21, 2008 | Canon PIXMA iP2000 InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
65 people viewed this question
old marine
old marine
