Question about Sharp AL 1631 Copier
Drum light on
I replaced the drum and the light will not go off. Is there a reset?
  • 29 Answers
Type this c-exposure-c-ratio and type 83 and start type 03 and start type 0 start 3 times.and after that press clear. c is for clear
Posted on May 06, 2008
Printer problem
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. We need to reset this now!
4.Open the front cover of the printer
5.Press and hold down Go button for about 4 seconds until all the LEDs light up.
6.Once all 4 LEDs are lit, release the Go button
7.Close the front cover.
8.Your drum is now reset.
Jul 18, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
Drum light flashing in spite of new drum unit and new toner cartridge
common problem.
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
    Reset the drum counter only when you replaced the drum unit with a new one.
Dec 30, 2009 | Brother HL-2040 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Aug 03, 2009 | Brother HL-2040 Laser Printer
The drum light won't go out!please tell me how do I reset it?
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Jan 15, 2009 | Xerox WorkCentre XD103F All-In-One Laser...
Beother Hl 2040 printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Brother HL-2040 Laser Printer
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Aug 28, 2008 | Office Equipment & Supplies
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Sharp AL 1631 Copier Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
