Question about Pelco DF5UY 0V21A Domepak In Ceiling Smoked Color 2.8 12MM Ai
Camera picture Picture appears to have a 'wavy' distortion for a few seconds, like the view of an object in the distance on a hot day; then the whole picture goes the way of the old TV 'horizontal-hold' problem...then comes back wavy, and then horizontal craziness again. The camera is getting a strong 26-27vdc; and the picture is fine at the camera, viewed through a portable monitor.
  • Anonymous Jan 09, 2009
    the picture is perfect clear and then gets wavy like heat rising for a engine
  • mrtechie Feb 08, 2009
    Hello there. I have the same Wavy Picture problem with one of our Esprit Pelco Camera. Would it have to do with the power supply? or with the cables? Please help me. Thanks.
The camera is long gone, replaced with another camera...but I believe the one giving me the problem was a board-camera, model IS90-CHV9. No problems with the new one (non-dome); a SONY, Digital Hyper-Had fixed camera. Appears that the original camera was just begining to 'fail'.
Thanks for the input though....
John
Posted on Oct 28, 2008
    Scholar:
  • 64 Answers
Let me preface this by my expertise with Pelco Products.....I have been working for Pelco for over 8 years now......So I need to know what the model number of the camera in you DF5 dome is because that Dome Pack number is not a valid part number....Here is how that part number brakes down...the DF5 tells me its a DF5 Dome and the UY is the section of that part number that doesn’t make sense...its not a valid number it should be either a CA ,MA or CC and the 0V21A tells me that it has a smoked bubble with the 13VD2.8-12 vari-focal Auto iris lens...... On a different note we do not make a fixed camera that will fit in a DF5 Dome that can take up to 26-27VDC (Direct Current) So if you are using 26-27 VDC you might have damaged the camera try a 24VAC transformer instead.....Good Luck and the more information you can give to me about the camera that is in the Dome the better.....let me know if this helped..
cbinny1
Posted on Oct 22, 2008
  • Craig Binford
    Craig Binford Oct 23, 2008
    I still need to know the model number of the camera inside the DF5 Dome...to better help you
The picture appears like a 3D picture with shadows. Usually tripled, and colors are strange. Peoples skin appears orange'ish-red, and white appears greenish...almost like holograms.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 24, 2010 | RCA P52939 52" Rear Projection Television
Screen picture offset
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Apr 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wavy picture on top and bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Sony KP-53HS30 53" Rear Projection...
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Camera not displaying image
after taking pictur. picture appear small or, technicolor screen
Jun 15, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Picture is very distorted
First of all, if you're still under warranty no use trying solutions that might be only temporary, go complain. Since you have normality relapses, it sounds like its something a reset could fix. Follow the instructions in your manual on how to perform a full reset, in case you no longer have the manual i'll attach that part of it to my post(just from a slightly different camera, if you have a digital manual for the 402 please post it). Now, if that doesn't work, i would suggest you try resetting the good old way - take out all batteries, disconnect all cables, and make sure the camera just lies there taking it easy for a few days, then try again. No go? it might be a problem with the memory card, try replacing. If you don't have one available try going to a repair shop/retailer and ask for one of their cards just to test it as a last resort before sending it for repair. Good luck
Feb 07, 2006 | Fuji FinePix F402 Digital Camera
Pelco DF5UY 0V21A Domepak In Ceiling Smoked Color 2.8 12MM Ai Logo
354 people viewed this question
Top Pelco Home Experts
Tony
Martin Clarke
Martin Clarke
Are you a Pelco Home Expert? Answer questions, earn points and help others
