I have a maytag neptune TL washer. The last few washes, the fabric softner and liquid bleach do not empty in to the wash...they just remain in their dispenser. Can you help?
  • 58 Answers
It could be mold.
try pouring bleach in each compartment and running it twice like this
and once after with no detergent bleaches or anything, just a normal wash on hot
this should help, if not u have to either clean the dispenser or replace it.
Posted on May 02, 2008
The bleach and softner dispenser does not work. The liquid softner would still be there at the end of the wash - never dispensed. I took out the dispenser and cleaned it, but no change. When I leave the...
Don't know if this is the answer, but my dispensers stayed filled also. repairman said the water wasn't flowing into the machine quickly enough and therefore not tripping the sensor that told the machine when to disburse the softener and/or bleach. He took the cold watersupply line loose, and the mesh was full of sediment. He said it wasn't necessary to replace the mesh. Sure enough, it started working immediately. He did the same for the hot water wasn't clogged.
Aug 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a frontload. The bleach is not dispensing. I have taken it apart and cleaned it but that did not seem to help. I do not use fabric softner so not sure if that side works
i have a maytag neptune 6500. we have tried both the bleach and the fabric softner. neither work. we've tried selecting every option on the machine, cleaning it, using hot water instead of warm; nothing is working.
i packed up the manual in the process of moving so i can't get to it right now. i'm surprised there's no solution yet online!
sorry this isn't a solution, but more problems.
Jun 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Washer - bleach and softner do not empty or have water left in them - how do i fix?
clean water inlet filter,then check to see if the outlet tubes from the dispenser to the tub are blocked or partially blocked with detergent.
I use liquid detergent... no problem.
Feb 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
