Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
WD 52525 lamp ballast avalability
I'm trying to find a source to buy a lamp ballast, part # 939p978010. Our local Best Buy wants an arm a leg and left nut for it, there must be another source for it.
Thanks,
Mike D
mike.daoust@jamarcompany.us
ironmike61@charter.net
    Genius:
  • Mitsubishi Master
  • 1,689 Answers
Contact Mitsubishi directly, and find out who their authorized parts distributor is. Mits may sell one directly to you.
It is an expensive part to begin with.
Jerry G.
Posted on Jun 07, 2008
Mitsubishi WD-52525 Rear projection hdtv I just turned my tv on and after about 1 minute I heard a pop, and the tv turned off. I tried turning it back on, and I have audio, but no picture...what could...
cpvsmv,
Your lamp blew. Hopefully the power surge did not take out the ballast. You need to get a new lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will not only tell you where to get the lamp at the best price but also walk you through the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52525 started a rubbing noise coming from the back area. I figure it's the light engine. Color was off and it won't restart, has a lamp light now. Lamp is 4 months old. Sound like light engine?
This sounds like your color wheel. this will affect the colors on your screen. Do check your lamp though, at 4 months you still should have a good lamp. Unless you have a bad ballast affecting the lamp as well. If you hear a rapid clicking or an electrical buzzing type noise. "ballast"
Apr 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My wd-52525 lamp indicator indicated that I needed a new lamp. I purchased a lamp, installed it and of course it still indicates a bad lamp. I took the lamp assembly and had it checked out by a tech and it...
Actually Tim, it seems more like a ballast issue, I recommend you replace it, since ity doesn't have enough energy to keep up with the lamp, and that's why you gte a lack of image.
Aug 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tried to replace bulb
Is this the part number you are using?
Mitsubishi 915P020010 Lamp
maybe you need to replace lamp ballast
Mitsubishi 939P978010 Pwb-pwr Lamp Rmd (V26/26++/vk26)
Apr 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
