Question about Xerox Phaser 8200 Laser Printer
Printer hangs on Power up - displays XEROX in LCD Window
Printer will not start up - any clues, this happened following a power outage.
    President:
  • 2,072 Answers
Do any of the fans operate ? Is there any aperance of the power switching on?
Look in the back of the printer and see if you notice any leds on in the machine.
If there is no presence of any power, the electronics module has most likely failed.
Posted on May 02, 2008
8560 printer shut itself down and will not true back on
The following lists the chain of events that occur when you turn on a printer. You can follow this list as one means of determining if the printer is operating correctly. The exact chain of events depends upon the last power down condition and where the printer has last determined the printhead is positioned, this is stored in non-volatile RAM. The Checklist is the primary reference for troubleshooting power-up problems.
1. Power cord is plugged in and the power switch is turned on:
2. Power supply senses AC line voltage conditions (110 VAC or 220 VAC)
and enables DC voltages. If an overload occurs, the printer turns off the high voltage DC supplies, causing a "blink" effect on the Control Panel LEDs.
3. BIST test flashes the PE LED very briefly at a fast rate until the end of the
next test.
4. The Boot loader performs CPU initialization and RAM test. It then sends
the boot loader version to the serial port.
5. Power-On Self Test (POST) initializes the Control Panel. The Control
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD
and waits two seconds. During this time the operator can press the Back
button to bypass the remaining POST test.
6. Low level Power-On Self Test (POST) diagnostics are performed. The
Control Panel displays status messages as each sub-test is performed.
This test takes about 8 seconds. All LEDs are off during the test.
If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
If the test detects an error, the error message displays on the LCD and the printer flashes the LEDs with a repeating error code pattern.
7. The VxWorks operating system is initialized and engine code is started.
This takes about 15 seconds. The Xerox logo is displayed.
8. Print Engine Self Test (PEST) diagnostics are then performed. These test
the heaters, clutches, motors and solenoids. As each clutch is tested, you hear clicking with four high tones as each motor is tested. This test takes about 30 seconds.
9. The printer now runs the mechanical initialization. The exact sequence
depends on the initial position of the printhead and wiper assembly.
Feb 28, 2014 | Xerox Phaser 8560MFP Laser Printer
8560 shut down and will not turn back on
next test.
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD and waits two seconds.
During this time the operator can press the Back button to bypass the remaining POST test.
Control Panel displays status messages as each sub-test is performed. This test takes about 8 seconds. All LEDs are off during the test. If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
My xerox phaser 8550 displays as offline. how do i get it up and ready to print?
First you need to find out why its offline, it could be the printer is off or the connection to the network or computer is unplugged or loose or just a wacky problem when there is a power outage from time to time or you changed some settings and never reboot your computer.
Try going to Start > Printers and Faxes > Right click on the Phaser printer to check the status there and right click > properties >Ports tab > select your printer and then configure port. a port settings window should open which displays the printers name and IP address. You can also find the IP address on the control panel on the printer scroll down to Information > Printer Identification and the IP address and other printer info should be displayed there.
Copy the IP address and paste it in the browsers address bar and check the status of your printer there, check if there are any jobs waiting to print, try clearing all of them, check the status page to see if there are any issues such as low ink, etc.
After running thru trouble shooting options and help menus there if all else fails, restart your printer by powering down, do the same for your computer and restart them both. I've had these issues before and sometimes just a reboot will correct itself.
Sep 09, 2009 | Xerox Phaser 8550/DT Thermal Printer
LCD screen blank on our Xerox 8560 Printer
You should replace the control panel yourself 802K93650. It's a 5 minute job.
-Whit :)
Jun 24, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 8560 DN. Had power outage then display lit but no text.
Under your printer settings on your PC - if you to to the properties you can view the ports - should give you the IP there , depending on how you have it setup..
some printers have a "Test" button next to the network card.. See if you have one there..
Jun 17, 2009 | Xerox Phaser 8560DN Laser Printer
No power but ON button flashing
Quickest fix for this is probably to temporarily unplug the monitor power cord.
For your other outages, I assume the monitor is connected to a computer, make sure the operating system power-save features have not disabled the video output signal from the computer ... if so, monitor should re-activate when you use the mouse or hit a key on the keyboard.
If your computer has two video outputs, make sure the primary display hasn't been shifted to the other one ... try it by moving the LCD data cable to the other video connector on the computer.
Dec 26, 2008 | Westinghouse LCM-19v1 Monitor
Trouble following brief power outage
apply any greese material like vaseline on the steel rod on which the cartridge carriage moves.if that rod is become rusty the carriage sometimes cannot move freely on it and this happens,
Nov 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
XEROX DOCUCOLOR 12 - Booting
if u getting this message in ur fiery just reinstal software... this only solution... and if u get this error in ur printer pls check error code in bottom of the display..
Aug 21, 2008 | Xerox DocuColor 12 Printer
Xerox Phaser 8200 Laser Printer Logo
91 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
