Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
DVI went bust
I have been happily using my Dell UltraSharp 2001 FP 20.1" monitor since September, 2004 when I purchased it. Recently the DVI input stopped working on me - I just get a black screen. I have tried a different video card and a different video cable and I am 99% sure that the problem is in the monitor itself. Any thoughts on repairing that? Where I could send it to be repaired? Could I fix this myself with an off-the-shelf part? Thanks!
    Sergeant:
  • 458 Answers
Have you contacted Dell? I am sure the warranty is gone but they might try to help. You can take it to a T.V. shop and have them check it. Sometimes a repair cost more than a monitor though. Acer has the best monitor that I have seen. I put some to a test at Staples and Acer was the only one that could stay working at a high resolution. Strange because Acer is usually ****. Good luck. Sorry I could not give you a better answer. I hope that I put you on the right track though. Does that monitor have a VGA connection on it that you can use. Some have both. Maybe you can get an adapter for your video card. Most cards come with one.
Posted on May 29, 2008
Dell 1504FP hdmi
It doesnt matter how many different ways you connct the monitor it will only support one input at a time
May 12, 2014 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
If you add a DVI adapter to the the DVI cable going to the Dell Inspiron 580 VGA input, do you get true DVI quality? Can you use a DVI to HDMI adpater?
For the best results, you a straight DVI cable.
VGA is analog, while DVI is digital. The quality will not be as good a a regular DVI cable.
You can use a DVI to HDMI.
I use one going from my PC to TV and the quality is awesome.
Mar 03, 2011 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell 2001 fp monitor has 2 blue horizontsl line on left side of screen and sometimes become white block
This not good! the problem is in the LCD panel display, and there is no way to repair this on a practical scale, this would not be a cost effective repair, far cheaper to replace the monitor.
Feb 07, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My dell monitor wont display my pc image
Make sure you use the correct selection for your input (the leftmost silver button) to cycle through DVI-D, D-Sub, S-Video, and composite.If you are using this as a second monitor from your laptop, you have to activate the secon dmonitor using your keyboard or the operating system.
Sep 25, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Yellow line
It sounds like a hardware problem ,if it still has warranty then you should return it.
It could also be a faulty vga card the only way to test would be to connect monitor to another computer.
Good Luck
Aug 18, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Detech Input message on the screen at the starting
I have the same monitor and assume you have both analog and digital inputs. In other words, both a DVI and standard analog monitor input. I noticed on mine that there was a "factory reset" on the menu. Have you tried that? What type of video card are you connecting to? DVI? Do you have any adapters or gender changers connected to it?
Let me know.
Jason
Dec 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell Monitor green 1 in bottom left panel
can this monitor handle dvi and vga I would guess that it is connected to the #1 input
Apr 30, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 2001FP
Chances are the driver tabs inside from the panel to the internal controller board have failed. This is the actual controller board that the internal video card connects to (hidden under the silver cover on the back of the physical panel).
It is not a cheap repair, and it is normally best to source another panel, or just replace the monitor all together.
Oct 17, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
Alun Cox
