posted by catsfix32 on May 02, 2008
Hello to all,
I put new ink into the printer (making sure the plastic covers where off).
the printer will not spray ink onto paper...the computer says printer is ready and indicates there are no problems with communication, etc.
the display of ink capacity shows all ink full.
still no ink getting to paper
thanks
Roland
Best Solution
posted on May 06, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I am An Epson authorised repair agent here in New Zealand...the symptom you have is either a failed head or a failed logic PCB or both, Epson recommend replacing both at the same time, it is nothing you have done that has caused this issue, if it is warranty, it should be replaced by Epson, if it is outside warranty then it would not be worth fixing,
In my opinion Epson are good printers, and only a small number of printer do this fault. it is unfortunate but not unheard of and I would not say it is a common problem.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 13, 2008
i suggest first trying to reseat the cartridges then do atleast 3 head cleaning thru the printer driver. so that if it was clogged it would flush any dried ink. after that dod a nozzle check to see if there was any improvment. if you do see some improvement i'd do a couple more if not id call epson if you were under warranty.
Suggest a new solution for this problem
Post a New problem for Epson Stylus CX6400 All-In-One InkJet
Email this problem
Email this problem
Can you Help with these Printers problems?
Epson Stylus CX6400 All-In-One InkJet Printer
Ink Cartridge
Ink Cartridge
The cyan ink wont print, it is... Answer This...
Scanner problem
Scanner problem
I have an Epson Stylus CX6400... Answer This...
10000xl won't power up
I am unable to turn my scanner... Answer This...
Epson Stylus CX6400
Epson Stylus CX6400
I was given this printer with... Answer This...
CX6400 Power supply
CX6400 Power supply
Printer has worked great for 2... Answer This...
Repair Service
Find Printer Repairman Near You:
