Question about Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one. It looks staightforward but is there anything I need to be aware of - for example do I need the unscrew the fridge door panel the wooden panel that bears the hinges?
  • TonyH1946 Jun 06, 2008
    I have the same problem, I've got new hinges, but can't see how to remove the hinges without taking the fridge out - i.e big job. Can anybody advise please ?
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
I have a large Neff refrigerator with a small freezer compartment at the top (the model no is not on the booklet or the fridge) the freezer door is broken - can i get a replacement? thank you Paul...
Hello Paul,
Try looking on ebay for a second hand or spares repair model.
Also try some of the refurb places where the cosmetic returns get sent with minor damage or faulty components.
PS:any chance you have fitting instructions for an integrated K4664 model ?
Mine came with no instructions how to reverse the door and fit to the wooden kitchen doors so and cant find any on the Neff website.
Thanks
I
PS:
Mar 01, 2009 | Neff K4664 Top Freezer Refrigerator
Neff american fridge freezer, ice dispenser
Are your ice cubes to big or in the dispenser door not opening all the way both can be fixed adjust the flow timer on the ice maker or replace the door dispenser
Jul 27, 2008 | Neff K3965XO Side by Side Refrigerator
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
Refrigerators Logo
1,887 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
